Home > Maintenance & Modifications > Alternator replacement on TDV8
chris_J_G
Hi,
My alternator on TDV8 has decided to pack in this morning, no local dealers can touch it for at least a week including a couple of Land Rover specialists.
As I am now out of warranty my own workshops are going to have a go at replacing once the new one arrives in the morning, it all looks pretty tight to get at, anybody have any experience of carrying this out or advice for me to pass on to my mechanics in terms of making the job any easier. Would be much appreciated.
Regards
Chris MY07 TDV8 HSE (BAS Remap), Java, Privacy Glass,Tasmods.
Post #269863 Tue Jun 29 2010 2:30pm
Bobby
Generator TDV8  Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #269939 Wed Jun 30 2010 12:11am
MAW
Shocked Thumbs Up
Post #269943 Wed Jun 30 2010 6:13am
chris_J_G
Many thanks Bobby that will be a great help ~ much appreciated
Post #269951 Wed Jun 30 2010 7:48am
stevietee10
United Kingdom 2005 Range Rover Sport TDV6 HSE Maya Gold
Hello Bobby,
Do you by any chance have the same document for the TDV6 engine
I'm desperate !! Big Cry
Thanks
Steve
Post #273627 Wed Aug 11 2010 3:12pm
Bobby
Yes, I do. Malaysia Boleh!
Post #273675 Wed Aug 11 2010 11:49pm
stevietee10
Hi Bobby
Could I have it then please ?
Thanks, Steve
Post #273693 Thu Aug 12 2010 8:28am
Bobby
OK, here you are then. Wink Malaysia Boleh!
Post #273706 Thu Aug 12 2010 11:39am
cuyunaNZ
New Zealand
2008 sport 3.6 TD alternator
vin number SALLSAA238A158773
Gidday Folks
I'm trying to make a repair to a alternator but would be easier if I had the alternator part number, this one hte sticker is gon, I believe it might be a denso unit but I havnt seen a denso number.
Rectifier faulty ( too lightly built, look like old school 35 amp diodes )
3 terminal plug can h, can l, batt.
Regards Don
Post #346967 Fri Jun 15 2012 2:50am
hannez82
Sweden 2008 Range Rover Sport TDV8 HSE Java Black
I'm replacing my alternator on my tdv8 but I need help understanding how to remove the Air Cleaner. Does anyone have the Air Cleaner (19.10.01) information?
Perhaps I need the Accessory Drive belt (86.10.03) also.
Best regards, Hannes
Post #509428 Sun Nov 06 2016 2:01pm
Paddi
Hi Hannes,
Have a look in my gallery here:
http://www.rrsport.co.uk/gallery/thumbnails.php?album=3775
You should find the sections you are looking for as pdf (although the section numbering differs from that which
you quoted as the pages are from a different version of the manual?)
Id've also trie to post them below as images but not sure if this works Confused
 2008 MY Java Black TDV8 HSE
Post #509516 Mon Nov 07 2016 4:49pm
Bobby
TDV8
Air Cleaner
Accessory Belt Malaysia Boleh!
Post #509532 Mon Nov 07 2016 8:27pm
hannez82
Many many thanks bobby! The air cleaner is now off but i cant figurer out how to remove The cooling shroud. I need to remove it so i cant remove The belt. Do you have this info also?
Best regards Hannes
Post #509736 Thu Nov 10 2016 10:28am
hannez82
To be more precise. I dont understand this step:
". Remove the viscous coupling.
For additional information, refer to: Cooling Fan (303-03E Engine
Cooling - TDV8 3.6L Diesel, Removal and Installation)."
Post #509737 Thu Nov 10 2016 10:30am
Bobby
Hope these will help..
Cooling Fan Shroud
Cooling Fan
Cooling System Partial Draining... Malaysia Boleh!
Post #509741 Thu Nov 10 2016 11:37am
