Home > Tips & Tricks > Get warmer quicker, stay hotter and save fuel
RRUK
I've found that by using the Econ button on the heating system it warms up faster and also means I don't need to have the temperature up to maximum to stay warm.
It cuts off the air con pump, thereby saving a little fuel along the way and seems to be much hotter.
Then you only need use the air con when its hot or when you need to dry the air to prevent steamed up windows.
06MY FFRR Vogue TD6, JE Stage 1 Tune, Chrome Tubes, Full Privacy, Full Fat, Full On.
Post #79513 Thu Feb 01 2007 5:53pm
leaving the AC compressor turned off will eventually lead to bacteria growing on the evaporator - this leads to a smelly socks / cabbage smell and 'could' lead to infections too (I didn't say that right Neutral )
Post #79520 Thu Feb 01 2007 6:14pm
aam1234
2007 Range Rover Sport Supercharged Rimini Red
One needs to turn on the A/C once a month or so even in winter, otherwise the compressor might get dry. This is what I heard, I could be wrong.
Post #79524 Thu Feb 01 2007 6:30pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
Correct. No need to have AC on during the winter.
ECON saves about 2-3l/100km! 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. 22" Overfinch Tiger alloys.
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit, no-cats free-flow exhaust system, Hamann ECU, K&N Air filter, modified supercharger pulley, and more.......... 460bhp, 13.856s 1\4 mile, 155+mph topspeed.
2003 BMW 525iA
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #79529 Thu Feb 01 2007 6:35pm
aam1234
Hi tf9,
So we should or shouldn't turn on the A/C once in a while.
Post #79535 Thu Feb 01 2007 6:58pm
tf9
Hey Smile
You should turn it on for about 20-30mins once per month. Rest of the time you can safely drive with ECON mode ON Smile 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. 22" Overfinch Tiger alloys.
2003 BMW 525iA
Post #79540 Thu Feb 01 2007 7:09pm
aam1234
Cool (literally) Thumbs Up
But 20-30 minutes is a bit much Sad
Post #79551 Thu Feb 01 2007 7:24pm
Cliff H
There is a mod to make the temperature more accurate as you may find that you are forever turning up the temp on a longer run just to keep warm.
This is due to the temp sensor (behind the dash) picking up heat from the radio etc and so giving a false reading.
The mod is basicly a foam sock that goes over the sensor.
Ten minute job at the dealers.
Post #79582 Thu Feb 01 2007 8:14pm
tf9
Yeah... noticed that one... I start the ride with 20c and then end it with like 22-23c Confused 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. 22" Overfinch Tiger alloys.
2003 BMW 525iA
Post #79585 Thu Feb 01 2007 8:18pm
Cliff H
This is the TSB for the 'sock' I should think it is the same for the D3 and RRS though you would have to check this.
Later cars should have it already fitted at the factory.
TSB LA412-003
Post #79589 Thu Feb 01 2007 8:23pm
Location: Growing old is mandatory; growing up is optional.
Cool thanks for that info Cliff Thumbs Up RRS TDV6 Gone but still around
Shaguar Hard Type (know you all miss her but she's gone)
Oh and i love the girlzzzzzzzzzz!!!
Post #79755 Fri Feb 02 2007 12:15am
Brian Mason
I leave mine on all year 'round.., just doing my bit for global warming!!! Rolling with laughter Rolling with laughter Rolling with laughter
Post #79766 Fri Feb 02 2007 12:26am
Your bit to Censored it up!!
Rolling with laughter Rolling with laughter RRS TDV6 Gone but still around
Post #79769 Fri Feb 02 2007 12:28am
tf9
How dare you, i'm a greenpeace adept and you are shocking me Shocked 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. 22" Overfinch Tiger alloys.
2003 BMW 525iA
Post #79771 Fri Feb 02 2007 12:29am
See your doing your bit as well with your green cars TF9!! Laughing RRS TDV6 Gone but still around
Post #79772 Fri Feb 02 2007 12:31am
