| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Tips & Tricks > Get warmer quicker, stay hotter and save fuel |
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2211
I've found that by using the Econ button on the heating system it warms up faster and also means I don't need to have the temperature up to maximum to stay warm.
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6606
leaving the AC compressor turned off will eventually lead to bacteria growing on the evaporator - this leads to a smelly socks / cabbage smell and 'could' lead to infections too (I didn't say that right |
| tf9 Joined: 07 Jun 2006 Location: Moscow, Russia Posts: 640
| aam1234 Joined: 08 Aug 2006 Location: Somewhere out there Posts: 450
Hi tf9,
Hey |
Cool (literally) |
| Cliff H Joined: 03 Dec 2005 Location: uk Posts: 3233
There is a mod to make the temperature more accurate as you may find that you are forever turning up the temp on a longer run just to keep warm.
This is the TSB for the 'sock' I should think it is the same for the D3 and RRS though you would have to check this.
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 19931
Cool thanks for that info Cliff |
| Brian Mason Joined: 31 Aug 2006 Location: - - - - - - - - - - - - - Posts: 5303
I leave mine on all year 'round.., just doing my bit for global warming!!! |
Your bit to |
See your doing your bit as well with your green cars TF9!! |
