Home > Technical > 2.7 TDV6 will not start |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 122 |
Did you bleed the fuel LP system? |
Sat Jun 13 2020 5:09pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
If the code reader is reporting a crankshaft sensor error, then it means the ECU can't see any timing pulses from the crank, and is thinking that the crank is not rotating, so it won't fire the injectors (as it has no idea what the timing relationship is).
Wed Jun 17 2020 1:52pm |
evets Member Since: 11 Jun 2020 Location: Manchester / Bolton Posts: 59 |
Cheers Bob could well be the problem can the wiring be checked from the top as the sensor is awkward behind turbo at back of engine? |
Wed Jun 17 2020 2:32pm |
Sorry, I don't know, I've not had to do it on mine. |
Wed Jun 17 2020 7:26pm |
i have new sensor but there should be wires from the sensor to the ecu which can be
Wed Jun 17 2020 8:52pm |
Sorry, I missed that you had replied.
Sun Jul 05 2020 12:50pm |
Solved the problem one of the last checks looked down oil filler turned engine camshaft not turning.
Thu Feb 11 2021 9:41pm |
