Home > In Car Electronics > Surround Camera Retro fit.
Brit Plumber
As the title suggests, I’m retro fitting Surround Cameras to my Sport. I’ve fitted a 2013 FFRR Module under the passenger seat but to get it working I need the camera cables. The L320 version used FAKRA connector cables and the cameras are £100 to £200 each. I opted for the later 2013 FFRR module as I have 2014 Discovery 4 mirrors (RRS2) with the 6 pin camera and these need the JAE connector cables. I had hoped I could buy the correct repair cables as you can with the FAKRA type for L319 and 320 but it appears these aren’t available as repair parts. So, are there any electronic experts who know a supplier or a breaker who will sell looms rather than hack them out?[/b] 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 Discovery 4 Mirrors AKA RRS2 (Done)
2014 L405 Surround Camera retro fit (WIP)
2013 RES Dual View Screen fit (Complete)
2016 LR4 RSE (WIP)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Gone)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #574480 Mon Feb 04 2019 9:38am
Brit Plumber
Project so far.
I’ve got some more cameras on the way and just need to source these cables.
The cameras are these 6 pin as fitted to the late Disco 4 and FFRR, the image on the screen is from the camera plugged into the module with a short loom from a mirror hence the view of the cabin.
Mods:
2016 LR4 RSE (WIP)
Post #574571 Mon Feb 04 2019 11:38pm
Will be very interested how that all works out, when I changed my mirrors I ended up fitting a couple of the rear view cameras in the mirrors as already had surround system and couldn't find leads of any sort to connect the RRS2 6pin into the RRS1 4pin system, also as the original cameras had the puddle light integral in camera have two permanent camera faults listed which I put down to the puddle lights although everything works fine. Would like to see if I could get rid of the faults.
Did find these before but never pursued it.
http://www.jae.com/en/index.html
Post #574573 Tue Feb 05 2019 12:10am
Brit Plumber
I’ll let you know how it goes Col.
The MX39 connectors from JAE are only available as an assembled loom which is a PITA. I have contacted a company in China who make these cables to see if they can do custom lengths and one offs.
Does your Surround System overlay graphical Park Distance warnings over the image in reverse gear? I’m not sure if the L320 system can do this. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 LR4 RSE (WIP)
Post #574854 Sat Feb 09 2019 11:19am
I get this sort of thing Chris if that is what you mean, don't know if same as RRS2 though, changes colour the nearer you get to things, yellow, orange then red I think along with the sensor beep increasing, also get the "bendy" yellow lines with the steering wheel movement.
Post #574855 Sat Feb 09 2019 11:46am
Brit Plumber
Thanks Col, I couldn’t get mine to work at first so wondered if the L320 never had it. But after seeing yours I cleared the DTCs and now it works a treat! 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 LR4 RSE (WIP)
Post #575000 Mon Feb 11 2019 10:02am
carlos50
I'm also keen to see how this turns out and what parts & coding are needed etc. Assume you wont get the surround camera icon on the main display without a new head unit?
I'm also keen to know if anyone has done a blind spot monitoring retrofit, does it just need new mirrors with the blind spot included and the sensors in the rear bumper to detect oncoming traffic then coding to activate or is it more complicated than that?
Does anyone on here offer this service, cant imagine the LR dealers will do it
Thanks
Carl
Post #575223 Thu Feb 14 2019 10:09am
Brit Plumber
You shouldn’t need a new head unit, it just needs the CCF updating to effectively turn the option on and then the icon will appear.
I’ve been looking at the blind spot mod but I can’t find much info on the L320 having it. Looking at the Disco 4 wiring manual it’s easily intallable but again it will be the CCF that could cause an issue.
As for the surround cam retro, I’ve taken a little step backwards as I can’t get my stupid spoiler off to replace the camera. I removed my test camera from the rear camera port and now I’ve refitted it with a brand new loom, I can’t get the PDC overlay back, I just have a lost com icon above the image. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 LR4 RSE (WIP)
Post #575234 Thu Feb 14 2019 12:10pm
