Home > In Car Electronics > Surround Camera Retro fit.
Brit Plumber
As the title suggests, I’m retro fitting Surround Cameras to my Sport. I’ve fitted a 2013 FFRR Module under the passenger seat but to get it working I need the camera cables. The L320 version used FAKRA connector cables and the cameras are £100 to £200 each. I opted for the later 2013 FFRR module as I have 2014 Discovery 4 mirrors (RRS2) with the 6 pin camera and these need the JAE connector cables. I had hoped I could buy the correct repair cables as you can with the FAKRA type for L319 and 320 but it appears these aren’t available as repair parts. So, are there any electronic experts who know a supplier or a breaker who will sell looms rather than hack them out?[/b] 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #574480 Mon Feb 04 2019 8:38am
Brit Plumber
Project so far.
I’ve got some more cameras on the way and just need to source these cables.
The cameras are these 6 pin as fitted to the late Disco 4 and FFRR, the image on the screen is from the camera plugged into the module with a short loom from a mirror hence the view of the cabin.
 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #574571 Mon Feb 04 2019 10:38pm
Will be very interested how that all works out, when I changed my mirrors I ended up fitting a couple of the rear view cameras in the mirrors as already had surround system and couldn't find leads of any sort to connect the RRS2 6pin into the RRS1 4pin system, also as the original cameras had the puddle light integral in camera have two permanent camera faults listed which I put down to the puddle lights although everything works fine. Would like to see if I could get rid of the faults.
Did find these before but never pursued it.
http://www.jae.com/en/index.html
Post #574573 Mon Feb 04 2019 11:10pm
Brit Plumber
I’ll let you know how it goes Col.
The MX39 connectors from JAE are only available as an assembled loom which is a PITA. I have contacted a company in China who make these cables to see if they can do custom lengths and one offs.
Does your Surround System overlay graphical Park Distance warnings over the image in reverse gear? I’m not sure if the L320 system can do this. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #574854 Sat Feb 09 2019 10:19am
I get this sort of thing Chris if that is what you mean, don't know if same as RRS2 though, changes colour the nearer you get to things, yellow, orange then red I think along with the sensor beep increasing, also get the "bendy" yellow lines with the steering wheel movement.
Post #574855 Sat Feb 09 2019 10:46am
Brit Plumber
Thanks Col, I couldn’t get mine to work at first so wondered if the L320 never had it. But after seeing yours I cleared the DTCs and now it works a treat! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #575000 Mon Feb 11 2019 9:02am
carlos50
I'm also keen to see how this turns out and what parts & coding are needed etc. Assume you wont get the surround camera icon on the main display without a new head unit?
I'm also keen to know if anyone has done a blind spot monitoring retrofit, does it just need new mirrors with the blind spot included and the sensors in the rear bumper to detect oncoming traffic then coding to activate or is it more complicated than that?
Does anyone on here offer this service, cant imagine the LR dealers will do it
Thanks
Carl
Post #575223 Thu Feb 14 2019 9:09am
Brit Plumber
You shouldn’t need a new head unit, it just needs the CCF updating to effectively turn the option on and then the icon will appear.
I’ve been looking at the blind spot mod but I can’t find much info on the L320 having it. Looking at the Disco 4 wiring manual it’s easily intallable but again it will be the CCF that could cause an issue.
As for the surround cam retro, I’ve taken a little step backwards as I can’t get my stupid spoiler off to replace the camera. I removed my test camera from the rear camera port and now I’ve refitted it with a brand new loom, I can’t get the PDC overlay back, I just have a lost com icon above the image. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #575234 Thu Feb 14 2019 11:10am
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Great post. interesting, has anyone...
retro fitted all round cameras to L494 I wonder?
I have a rear camera and always fancied front and more importantly side for parking. My wife is paranoid at scuffing our new wheels. 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #594121 Sat Feb 01 2020 10:33am
Brit Plumber
It’s not difficult as a DIY job but the most expensive part of it will be buying the mirrors (salvage is better as you only need the bottom trim) and the IID tool. The special cables aren’t cheap either but you may be able to obtain those through salvage also. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #594128 Sat Feb 01 2020 11:22am
Rs4-cab
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi
Did you ever get this sorted ?
If so do you have a list of part numbers and parts needed?
Post #613155 Sat May 01 2021 8:55pm
