Home > General > Frozen Radio Screen 'Land Rover' Logo
jaylow
Hi, im from germany and my english is not so good... I have a Range Rover Sport 2007 and a problem with the Touchscreen Freeze. There is still the green Land Rover logo and radio works but WITHOUT sound. There is no Sound and in the Touchscreen still the Land Rover Logo.
sometimes at the radio stands: Phone Mode and i can not do anything. But The Land Rover Logo Freeze all time.
I need help please.
Post #555689 Thu May 03 2018 4:41pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Hi, when I got mine the screen was frozen. I thought it might need a new unit but it turned out to be debris which was shorting out the contacts. The screen has metallic strips top and bottom and down both sides that don't connect in the corners (that I assume detect the position of your finger when you touch it). Dirt/debris had got down and was shorting them out. I stripped the unit out and cleaned it up with electrical spray and it is still working fine 18 months later.
Getting the unit out is a bit of a faff but there are videos on You Tube showing you how to strip the console to get access to the unit.
Best of luck Thumbs Up
Post #555692 Thu May 03 2018 5:53pm
jaylow
I took out the display and pulled out all the plugs and then adjusted everything again, it still does not work. I have now bought a used one and it will come in the next few days. Let's see if it works then. But I think that the problem is not on the display.
Post #555745 Fri May 04 2018 9:47am
d-9
Disconnect the battery for a few seconds, then reconnect it. Mine used to do that until I replaced the battery.
Post #555818 Fri May 04 2018 11:12pm
wilchesth
United Kingdom 2008 Range Rover Sport TDV6 SE Zermatt Silver
Any chance it could be a faulty navigation DVD unit? Try unplugging it before starting the engine. Worth a try. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #555867 Sat May 05 2018 9:29pm
geoffsnook
It sounds like you have a problem in the most loop and it maybe in the bluetooth modual Thumbs Up
Post #555885 Sun May 06 2018 9:29am
geoffsnook
One of these and disconnect you Bluetooth mo dual
https://www.ebay.co.uk/itm/Range-Rover-Spo...SwfjRZ73pR
Post #555886 Sun May 06 2018 9:31am
d-9
Just disconnect and reconnect the battery before messing around with the fibre loop, it's an easy test to see if it's a power issue or a module issue. Reading around the forums, its usually power, mine would do this every couple of days but since its had a new battery it's been fine.
Post #555922 Sun May 06 2018 11:41pm
geoffsnook
If it is the battery then put a multi meter across battery terminals and measure the voltage across the terminals with no engine running with the engine running and also with engine running and all electric switches on so air-con heated seats if you have them and lights then post the results on here Thumbs Up
Post #555926 Mon May 07 2018 8:11am
nikd
it will be the bluetooth unit. take the most connector out and then join the ends together inside the barrel of a biro. it will all come back to life then.
Post #556847 Fri May 18 2018 8:31pm
