Home > General > Frozen Radio Screen 'Land Rover' Logo |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Hi, when I got mine the screen was frozen. I thought it might need a new unit but it turned out to be debris which was shorting out the contacts. The screen has metallic strips top and bottom and down both sides that don't connect in the corners (that I assume detect the position of your finger when you touch it). Dirt/debris had got down and was shorting them out. I stripped the unit out and cleaned it up with electrical spray and it is still working fine 18 months later.
Thu May 03 2018 5:53pm |
jaylow Member Since: 03 May 2018 Location: Solingen Posts: 2 |
I took out the display and pulled out all the plugs and then adjusted everything again, it still does not work. I have now bought a used one and it will come in the next few days. Let's see if it works then. But I think that the problem is not on the display. |
Fri May 04 2018 9:47am |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Disconnect the battery for a few seconds, then reconnect it. Mine used to do that until I replaced the battery. |
Fri May 04 2018 11:12pm |
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 |
Any chance it could be a faulty navigation DVD unit? Try unplugging it before starting the engine. Worth a try. 2008 Range Rover Sport 2.7 SE Zermatt Silver. |
Sat May 05 2018 9:29pm |
It sounds like you have a problem in the most loop and it maybe in the bluetooth modual |
Sun May 06 2018 9:29am |
One of these and disconnect you Bluetooth mo dual
Sun May 06 2018 9:31am |
Just disconnect and reconnect the battery before messing around with the fibre loop, it's an easy test to see if it's a power issue or a module issue. Reading around the forums, its usually power, mine would do this every couple of days but since its had a new battery it's been fine. |
Sun May 06 2018 11:41pm |
If it is the battery then put a multi meter across battery terminals and measure the voltage across the terminals with no engine running with the engine running and also with engine running and all electric switches on so air-con heated seats if you have them and lights then post the results on here |
Mon May 07 2018 8:11am |
nikd Member Since: 12 May 2018 Location: manchester Posts: 4 |
it will be the bluetooth unit. take the most connector out and then join the ends together inside the barrel of a biro. it will all come back to life then. |
Fri May 18 2018 8:31pm |
