Home > General > parking senors / fb heater.fogs fixed
HEFF
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
so today i thought id check my lights...
front fogs dont work none of them only the back ones
fuel burner heater not working pulled fuse and put it back in as its ok still dont work
parking sensors not working
think i bought a lemon Thud Banging Head Banging Head Banging Head
Post #549043 Sun Feb 18 2018 3:52pm
FOGS AND Parking sensors are common issues.
Wires broken behind bumper possibly.
check fog fuse behind glovebox
Post #549047 Sun Feb 18 2018 4:39pm
HEFF
thanks for the reply Andy
ill check them asap any idea what fuse it is??
Post #549051 Sun Feb 18 2018 5:05pm
HEFF
yipeeee Laughing
sorted front fog lights 15amp fuse had blown behind the glove box
cheers andy Thumbs Up
now to figure out fuel burner n parking sensors Whistle
Post #549175 Mon Feb 19 2018 5:31pm
Pufftmw
FBH only kicks in when o/side temp is very cold as its there to help raise the water temp to get the car warmer quicker
Post #549178 Mon Feb 19 2018 6:06pm
needs to be around 4 to 5 °C (or less) for it to kick in once the engine is started
Post #549179 Mon Feb 19 2018 6:45pm
Paddi
Minimum temperature to start the FBH stated to be different depending on where you look in LR documentation but is definitely in the range of 4-6 degrees C and in my case seems to coincide with the snowflake symbol appearing in the dash display. Also remember it won't start if fuel level is below 1/4 tank.
Sometimes the FBH might be locked out and just needs to be 'purged' using a diagnostic tool such as a IID to get it going again. 2008 MY Java Black TDV8 HSE
Post #549180 Mon Feb 19 2018 6:47pm
HEFF
hey paddi
arrgh ok guys thanks, think ill forget about the fbh for now.
i pulled fuse for parking senors but no luck. then went round my rrs to clean sensors it worked for a minute the front ones. then when i tried it again straight after i just got the tone from the back of car and flashing light on dash button.walked round the car and couldn't hear them clicking?
i dont have a diagnostic tool cant afford the price for one Laughing but im sure its one from the rear thats causing the problem
ill sort it some how Thumbs Up Laughing fun n games these motors Wink
thanks lads
Post #549189 Mon Feb 19 2018 7:40pm
buy one or two sensors off ebay. (£10 each)
and swap them in the rear locations until they work
Post #549191 Mon Feb 19 2018 7:55pm
HEFF
ill do that cheers Andy Thumbs Up
(dont know why i didnt think of that ... Embarassed ) Rolling with laughter
thanks again Thumbs Up Bow down
Post #549193 Mon Feb 19 2018 7:59pm
you do need luck on your side, as the fronts can interfere with the rears
and there could be a wiring fault behind bumper.
But if you have a couple of sensors when you remove the bumper, you stand a chance of getting it working
Post #549208 Mon Feb 19 2018 9:39pm
HEFF
iv ordered a new senors so fingers crossed mate.
ill report back when they arrive and iv tried to find a fix Question .
cheers Andy
Post #549223 Tue Feb 20 2018 12:02am
Eaters
This might help with the parking sensors
http://www.rrsport.co.uk/forum/topic48459.html
My fix was not the first time that the wiring had been "repaired" and so I believe it is a design fault in the routing of the loom. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #549232 Tue Feb 20 2018 8:33am
HEFF
cheers eaters..
that looks awful in your pic the wiring is a mess Confused .glad you sorted it.
thanks for the post it gives me a idea what im up against ill check out that video. Thumbs Up
thanks Thumbs Up
Post #549302 Tue Feb 20 2018 7:43pm
HEFF
well iv tried the new sensor in the rear bumper but no luck Confused . will try it in the front asap
Post #552615 Thu Mar 29 2018 3:55pm
