Home > General > parking senors / fb heater.fogs fixed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4752 |
FOGS AND Parking sensors are common issues.
Sun Feb 18 2018 3:39pm |
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 |
thanks for the reply Andy
Sun Feb 18 2018 4:05pm |
yipeeee
Mon Feb 19 2018 4:31pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1047 |
FBH only kicks in when o/side temp is very cold as its there to help raise the water temp to get the car warmer quicker |
Mon Feb 19 2018 5:06pm |
needs to be around 4 to 5 °C (or less) for it to kick in once the engine is started |
Mon Feb 19 2018 5:45pm |
Minimum temperature to start the FBH stated to be different depending on where you look in LR documentation but is definitely in the range of 4-6 degrees C and in my case seems to coincide with the snowflake symbol appearing in the dash display. Also remember it won't start if fuel level is below 1/4 tank.
Mon Feb 19 2018 5:47pm |
hey paddi
Mon Feb 19 2018 6:40pm |
buy one or two sensors off ebay. (£10 each)
Mon Feb 19 2018 6:55pm |
ill do that cheers Andy
Mon Feb 19 2018 6:59pm |
you do need luck on your side, as the fronts can interfere with the rears
Mon Feb 19 2018 8:39pm |
iv ordered a new senors so fingers crossed mate.
Mon Feb 19 2018 11:02pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
This might help with the parking sensors
Tue Feb 20 2018 7:33am |
cheers eaters..
Tue Feb 20 2018 6:43pm |
well iv tried the new sensor in the rear bumper but no luck . will try it in the front asap |
Thu Mar 29 2018 2:55pm |
