Home > Maintenance & Modifications > Rubbery plastic under the wheel arches
Asil SAYAR
Turkey
It's a good practice to glue them during fitment.. You're lucky that they didn't pop-off.. Here in Istanbul most of RRS's don't have them Smile I glue new ones and they last forever Smile One life, live it...
Post #324601 Fri Dec 09 2011 7:13pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
fitted as per factory, took a few minutes once the area was cleaned, so cheap anyway no point in glueing
Post #324739 Sun Dec 11 2011 4:50pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
I know this is an old thread revival but I'm looking at replacing these parts, well I was but the inflation on these parts over 5 years !! Cheapest I can find these are £50 for the set of 4..
Post #491988 Mon Mar 28 2016 6:40pm
Try these, works out enough to do it twice.
http://www.ebay.co.uk/itm/GENUINE-LAND-ROV...33ae146990
Post #491989 Mon Mar 28 2016 6:56pm
panda
Go to eBay and search for
Rubber edge trim seal
About £4.00 for a metre
PANDA
Post #492004 Mon Mar 28 2016 9:11pm
Danv8
Awesome, thanks panda.
Post #492052 Tue Mar 29 2016 10:52am
Williamhh
Just a little update for general entertainment....a few years later!
My car (MY10 TDV8) is at the dealer for a new steering rack and I asked them sort out the warped rubber arch protectors. Apparently they were dealer fitted, not factory fitted, and are therefore not covered by warranty. My dealer tells me they don't really do anything.
I was told that there is an LR bulletin advising that when they warp they should be removed?!
Has anyone come across anything different? I haven't actually seen the LR bulletin and would like to cross check what I'm being told somehow.
All sounds a bit odd to me!
Post #544793 Thu Jan 04 2018 4:38pm
Williamhh
duckworthparts wrote:
Front CLB500061 �12.50+vat each
Rear CLB500051 �13.50+vat each
Are these prices still current Dan?
Thanks
Post #544794 Thu Jan 04 2018 4:40pm
beerbelly
United Kingdom 2007 Range Rover Sport TDV6 SE Stornoway Grey
you can get a set of four genuine land rover parts for 50 odd quid on ebay takes 5 mins to change just pull the old one out slide new one on .was one of the first things I did
Post #544816 Thu Jan 04 2018 7:43pm
DrRob
Bullshit! Fitted at the factory and not at dealership from new! They need replacing every few years when they start warping. Remove, clean area thoroughly and fit new ones. They protect the panel edge. Bulletin is right in that they should be removed when warped but always replace with new ones Thumbs Up Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #544824 Thu Jan 04 2018 9:00pm
If you use these it is enough to do the whole car twice if cut correctly, if mud laps are fitted might even squeeze enough to get three sets.
Post #544838 Thu Jan 04 2018 10:19pm
beerbelly
id agree there oe as mine came in sealed wrapping with Landover labels with part no's etc.
Post #544855 Fri Jan 05 2018 7:39am
