Home > Maintenance & Modifications > Rubbery plastic under the wheel arches |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
fitted as per factory, took a few minutes once the area was cleaned, so cheap anyway no point in glueing |
Sun Dec 11 2011 4:50pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
I know this is an old thread revival but I'm looking at replacing these parts, well I was but the inflation on these parts over 5 years !! Cheapest I can find these are £50 for the set of 4.. |
Mon Mar 28 2016 6:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Try these, works out enough to do it twice.
Mon Mar 28 2016 6:56pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Go to eBay and search for
Mon Mar 28 2016 9:11pm |
Awesome, thanks panda. |
Tue Mar 29 2016 10:52am |
Williamhh Member Since: 02 Dec 2013 Location: Suffolk Posts: 63 |
Just a little update for general entertainment....a few years later!
Thu Jan 04 2018 4:38pm |
Are these prices still current Dan? Thanks |
Thu Jan 04 2018 4:40pm |
beerbelly Member Since: 28 Nov 2017 Location: Teesside Posts: 27 |
you can get a set of four genuine land rover parts for 50 odd quid on ebay takes 5 mins to change just pull the old one out slide new one on .was one of the first things I did |
Thu Jan 04 2018 7:43pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Bullshit! Fitted at the factory and not at dealership from new! They need replacing every few years when they start warping. Remove, clean area thoroughly and fit new ones. They protect the panel edge. Bulletin is right in that they should be removed when warped but always replace with new ones Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Thu Jan 04 2018 9:00pm |
If you use these it is enough to do the whole car twice if cut correctly, if mud laps are fitted might even squeeze enough to get three sets.
Thu Jan 04 2018 10:19pm |
id agree there oe as mine came in sealed wrapping with Landover labels with part no's etc. |
Fri Jan 05 2018 7:39am |
