Home > General > New injectors all gunked up! |
DJDobsy Member Since: 25 Nov 2017 Location: Sittingbourne Posts: 19 |
Hi all, had a shaky idle issue which I took to local garage who confirmed 6 injectors failed when he plugged in. Took them off to be tested and had 3 ultrasonic cleaned (guy said they will get my by) the other 3 catastrophic failure so I bought 3 new ones. Installed them all and car ran fine for a week and now suddenly in limp mode with a shaky idle again!
Sun Dec 24 2017 1:18pm |
Hi Tim thanks for reply, when I changed the injectors I had under a quarter tank of diesel left in the tank (which had injector cleaner in as I was hoping that would cure the original problem before replacing them). After replacing them I filled up the tank with BP Ultimate and have done so since changing. So I don’t think it’s the fuel.
Sun Dec 24 2017 2:22pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1740 |
You do not have a fuel bug by any chance? Quite common on boats where the diesel is left for a while.
Sun Dec 24 2017 3:48pm |
Hi Jim, it’s been used more or less everyday since I bought it just over a year ago, so wouldn’t have thought so. I’m a bit puzzled to be honest. |
Sun Dec 24 2017 3:54pm |
You may have picked up some dodgy fuel, could be worth treating it anyway.
Sun Dec 24 2017 4:08pm |
I’ll chuck some cleaner through see what happens, thanks |
Sun Dec 24 2017 4:14pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
From my experiences with aircraft (kerosene), there has got to be some water present for the bacteria to really get going: by living on the fuel/water interface they can get everything they need to multiply and form a gloopy 'mat'. That sort of stuff usually bungs up the filter though. |
Sun Dec 24 2017 4:57pm |
Ok so I’ve had the RAC out to plug it in and see what’s going on...seems injectors to me but does any one here have any “code reading skills” and can work out what exactly is the problem from photo attached. Thanks I’m advance Steve |
Sat Dec 30 2017 8:52pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
THe nozzle of that injector is completely normal. Nothing to worry about
Sat Dec 30 2017 9:11pm |
Hi, yeah shakey idle and limp mode is now all the time. The full
Sat Dec 30 2017 9:29pm |
If all 6 were shafted, then all 6 should have really been replaced. I guess thats the next logical step... |
Sun Dec 31 2017 12:02am |
Thanks for your help mikey 👍 do you work at Bearmach? I’m trying to locate some leak off pipe clips, can’t seem to find them anywhere! Cheers Steve |
Sun Dec 31 2017 11:11am |
I am only a stockist
Sun Dec 31 2017 12:17pm |
Thanks again 👍 |
Sun Dec 31 2017 1:42pm |
