Home > General > New injectors all gunked up!
DJDobsy
Hi all, had a shaky idle issue which I took to local garage who confirmed 6 injectors failed when he plugged in. Took them off to be tested and had 3 ultrasonic cleaned (guy said they will get my by) the other 3 catastrophic failure so I bought 3 new ones. Installed them all and car ran fine for a week and now suddenly in limp mode with a shaky idle again!
Took out one of the cleaned injectors and it seems to be covered in gunk at the nozzle. Took off a new injector and same thing, gunk. Is this normal to gunk up so soon? Would this likely to be the issue?
55 plate tdv6 2.7
Full service inc fuel filter 6 months ago.
Any help appreciated!
Post #543985 Sun Dec 24 2017 1:18pm
Tim in Scotland
AFAIK it isn’t something that has been reported here before - I wonder if you need to try a different fuel supplier/ brand and maybe something like Miller’s Injector Cleaning and Cetane enhancing additive added to what remains in your present tank of fuel. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #543987 Sun Dec 24 2017 2:14pm
DJDobsy
Hi Tim thanks for reply, when I changed the injectors I had under a quarter tank of diesel left in the tank (which had injector cleaner in as I was hoping that would cure the original problem before replacing them). After replacing them I filled up the tank with BP Ultimate and have done so since changing. So I don’t think it’s the fuel.
Maybe another 3 new injectors, just seems strange for the amount of gunk in them considering it’s only been a week (unless that’s normal I don’t know)!
Post #543988 Sun Dec 24 2017 2:22pm
jimbg
You do not have a fuel bug by any chance? Quite common on boats where the diesel is left for a while.
Has the car car been left for a long period? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #543990 Sun Dec 24 2017 3:48pm
DJDobsy
Hi Jim, it’s been used more or less everyday since I bought it just over a year ago, so wouldn’t have thought so. I’m a bit puzzled to be honest.
Post #543991 Sun Dec 24 2017 3:54pm
jimbg
You may have picked up some dodgy fuel, could be worth treating it anyway.
Google Diesel fuel bug to learn more. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #543993 Sun Dec 24 2017 4:08pm
DJDobsy
I’ll chuck some cleaner through see what happens, thanks
Post #543994 Sun Dec 24 2017 4:14pm
HughN
Wales
From my experiences with aircraft (kerosene), there has got to be some water present for the bacteria to really get going: by living on the fuel/water interface they can get everything they need to multiply and form a gloopy 'mat'. That sort of stuff usually bungs up the filter though.
Post #543998 Sun Dec 24 2017 4:57pm
DJDobsy
Ok so I’ve had the RAC out to plug it in and see what’s going on...seems injectors to me but does any one here have any “code reading skills” and can work out what exactly is the problem from photo attached. Thanks I’m advance Steve
Post #544405 Sat Dec 30 2017 8:52pm
Disco_Mikey
THe nozzle of that injector is completely normal. Nothing to worry about Thumbs Up
However, you really need the fault codes cleared, and re-read after a short road test
Is it a shaky idle at all times, or only when cold?
Post #544407 Sat Dec 30 2017 9:11pm
DJDobsy
Hi, yeah shakey idle and limp mode is now all the time. The full
Story is I had a shakey idle but fine when driving, took it to my local garage and he said all 6 injectors need replacing. I wondered how if it drove fine and was just a shaky idle so I removed all 6 and gave them to Kent Injection to test and clean if needed. They came back and said yes all 6 have failed the test but 3 catastrophic failure and 3 may be ok for now. So I bought 3 new ones and put on the passenger side bank and put the 3 best old ones in the driver side bank. All was then fine for a week then suddenly it went into limp mode with a shakey idle and a shakey ride. So now I’m wondering if I need to replace the other 3 injectors, called out the RAC to plug in and see if the codes would confirm this. But I’m still not sure 😩. Any help is fully appreciated
Post #544408 Sat Dec 30 2017 9:29pm
Disco_Mikey
If all 6 were shafted, then all 6 should have really been replaced. I guess thats the next logical step...
Post #544416 Sun Dec 31 2017 12:02am
DJDobsy
Thanks for your help mikey 👍 do you work at Bearmach? I’m trying to locate some leak off pipe clips, can’t seem to find them anywhere! Cheers Steve
Post #544433 Sun Dec 31 2017 11:11am
Disco_Mikey
I am only a stockist Thumbs Up
Try Citroen for the clips Wink Thumbs Up
Post #544437 Sun Dec 31 2017 12:17pm
DJDobsy
Thanks again 👍
Post #544442 Sun Dec 31 2017 1:42pm
