Home > General > Engine top end strip down
Page 12 of 13 <123 ... 111213>
DerrekL
Andy K wrote:
Wondered how u were going.
Glad it's running.
As for the F check the connectors behind the battery. There are 2 that sort of float.
Black. And grey.
IID will drain all air and lower.
To get air out. Try loosening pipes on the valve block in front of compressor.
Think air will stay in struts though.
The lower button won't work?
Yes indeed, I can only get to it when not at work, then sometimes could see it far enough, oh well glad also got it working Thumbs Up
I do see only one connector that 'floats' behind the battery but didn't see any mate to plug it into, I will check that out again...
The lower button doesn't seem to take it all the way to the bump stops, also I do have the Christmas lights displaying on the dash just now so maybe that's air sus related. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #538584 Wed Oct 18 2017 11:49am
there's a black connector low down near battery (at back)
and a grey connector which clips to the plastic side of the battery compartment.
these get disconnected when doing the rear belt
Post #538623 Wed Oct 18 2017 6:25pm
DerrekL
I'm still getting the F transmission message on the dash and it is in limp mode Confused
I checked all transmission plugs from behind the battery and still have this small plug left over. I can't see or find a mate for this plug.
P38 4.6 HSE V8
Post #539156 Wed Oct 25 2017 8:57am
That's for the battery during transit when new.
THe grey connector to the side was one of the ones I talked about.
Is the black one below ok ?
Post #539171 Wed Oct 25 2017 12:13pm
what dash messages are you getting ?
Post #539172 Wed Oct 25 2017 12:14pm
DerrekL
OK good... plug not required, that's good news.
All other plugs in that area behind the battery have a place to go, no issues there.
The message displays something like 'limited gears only...' I will need to check exactly what the message displays. But when I last drove it is not getting any gears, seems to be in limp mode only. BTW it seems to rev up OK when in park.
Next picture quiz: Thumbs Up
Got this plug also spare!!!! which is on the LH side bank, again there is no other mate for it nearby. Every other plug in that area has a mate. Recognise it?
P38 4.6 HSE V8
Post #539176 Wed Oct 25 2017 1:25pm
Disco_Mikey
Fuel Rail Pressure Sensor
Post #539186 Wed Oct 25 2017 3:20pm
DerrekL
OK cheers Mikey, and where might that plug into? as there is no other plug around that area. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #539188 Wed Oct 25 2017 3:44pm
I think that's the cam sensor on passenger head, and would explain it
I think you should have moved over the old old cam sensor to the replacement passenger head.
Finding where in goes is a little tricky. You sort of have to do it from the top of the engine, buts its on the side.
have a look at the old head
Also check :
knock sensors plugged in (grey connectors on top of engine)
EGR's plugged in (all 3)
Post #539201 Wed Oct 25 2017 6:17pm
Disco_Mikey
The pressure sensor on the end of the fuel rail Whistle
It's not the Cam sensor. The car wouldn't start off thatbwas unplugged. And it's grey. As is the EGR connector which has 5 wires
The only thing it can be is the rail pressure sensor
Post #539213 Wed Oct 25 2017 7:58pm
That looks like the front of the engine to me with the cam belt cover.
On my engine there are no fuel pressure sensors at the front of the engine.
Only a 2 pin temp sensor in the middle of the V
Some engines will start without cam sensor in limp mode.
Can't remember what the cam sensor plug looks like but I do admit it's small
Yes I know thats not the EGR plugs but they are worth a check
Embarassed Bow down
Post #539215 Wed Oct 25 2017 8:21pm
Disco_Mikey
Rail sensor is in a different location between your EU3 model and his EU4 Thumbs Up
The TDV6 certainly won't start without a correct cam sensor signal
Post #539227 Thu Oct 26 2017 1:11am
DerrekL
Yes indeed Embarassed I was actually pushing the plug out the way but against the thing it should have been plugged into... the end of the fuel rail. How did I not see that DOH!
All plugs seem to now have a home and when I started the car no 'F' gearbox message on dash for a wee while i.e. drove it a few hundred meters but it still insists in staying in limp mode and F appears intermittently. Brake switch seems OK, battery seems OK. Anything else worth checking or replacing? It's surely something electrical/software related, worth getting the codes read and deleted? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #539231 Thu Oct 26 2017 8:28am
DerrekL
Embarassed Bow down
Thanks Andy, all plugs should now be in their respective places, hopefully Thumbs Up I just need to sus out what is going on with this limp mode carry on. I have checked the brake switch, battery as I have read in previous posts this can be a source of this kind of trouble.
The christmas tree dash lights come on after a couple of minutes but if I turn car off/on the lights go out but it still is in limp mode. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #539233 Thu Oct 26 2017 8:35am
I guess you need to think back to what you have touched.
and what sensors (if any) you have reused off the replacement heads
(excluding green oil pressure.)
Post #539264 Thu Oct 26 2017 12:49pm
