Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
there's a black connector low down near battery (at back)
Wed Oct 18 2017 6:25pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
I'm still getting the F transmission message on the dash and it is in limp mode
Wed Oct 25 2017 8:57am |
That's for the battery during transit when new.
Wed Oct 25 2017 12:13pm |
what dash messages are you getting ? |
Wed Oct 25 2017 12:14pm |
OK good... plug not required, that's good news.
Wed Oct 25 2017 1:25pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Fuel Rail Pressure Sensor |
Wed Oct 25 2017 3:20pm |
OK cheers Mikey, and where might that plug into? as there is no other plug around that area. RRS 2.7 HSE Stornoway Grey
Wed Oct 25 2017 3:44pm |
I think that's the cam sensor on passenger head, and would explain it
Wed Oct 25 2017 6:17pm |
The pressure sensor on the end of the fuel rail It's not the Cam sensor. The car wouldn't start off thatbwas unplugged. And it's grey. As is the EGR connector which has 5 wires The only thing it can be is the rail pressure sensor |
Wed Oct 25 2017 7:58pm |
That looks like the front of the engine to me with the cam belt cover.
Wed Oct 25 2017 8:21pm |
Rail sensor is in a different location between your EU3 model and his EU4
Thu Oct 26 2017 1:11am |
Yes indeed I was actually pushing the plug out the way but against the thing it should have been plugged into... the end of the fuel rail. How did I not see that DOH! All plugs seem to now have a home and when I started the car no 'F' gearbox message on dash for a wee while i.e. drove it a few hundred meters but it still insists in staying in limp mode and F appears intermittently. Brake switch seems OK, battery seems OK. Anything else worth checking or replacing? It's surely something electrical/software related, worth getting the codes read and deleted? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Thu Oct 26 2017 8:28am |
Thanks Andy, all plugs should now be in their respective places, hopefully I just need to sus out what is going on with this limp mode carry on. I have checked the brake switch, battery as I have read in previous posts this can be a source of this kind of trouble. The christmas tree dash lights come on after a couple of minutes but if I turn car off/on the lights go out but it still is in limp mode. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Thu Oct 26 2017 8:35am |
I guess you need to think back to what you have touched.
Thu Oct 26 2017 12:49pm |
