Home > Technical > washer jets not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
I thought the headlight wash relay was under the bonnet, but will have to check tonight |
Tue Aug 08 2017 12:06pm |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 96 |
I had the exact same issue, fuses were all ok however the headlight washer pump ( which is separate )was totally seized through corrosion, replaced it and all ok.
Wed Aug 09 2017 1:25pm |
