Home > General (L494) > Windscreen Smear
kljw
Scotland
Windscreen Smear
Hi
when using the wipers, I get a smear directly in from the drivers view, seem to remember something about this, but cannot find the thread. has / does anyone else encounter this issue? and has it been resolved? find it very distracting and dangerous.
Post #513548 Wed Jan 04 2017 6:00pm
scrumps
There's a modified wiper arm & blade (I think).
Quote TSB00918v2 at your Dealer.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #513552 Wed Jan 04 2017 6:22pm
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
I had the same problem, changed the wiper blades for Bosch "Flat" blades (available from Halfords or the ubiquitous internet auction site) and not had a problem since!
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #513568 Wed Jan 04 2017 7:43pm
rangiejools
Australia
I tried Bosch Twin Blades..seemed to work but after a couple of weeks got the dreaded smear again!
Will mention that TSB to my dealer. SDV8 arrived and fantastic even the infotainment!
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #513626 Thu Jan 05 2017 12:40pm
BigBen
http://www.rrsport.co.uk/forum/topic39886.html
The above link will take you to the original posts. For what it is worth the Bosch blades I mentioned in that earlier topic are still working with no smear and I am delighted with them as the smear issue is a real nuisance. Still on the original screen - now 2 1/2 years old.
Post #513711 Fri Jan 06 2017 5:42pm
Tim in Scotland
Having just had a new windscreen fitted I also replaced the wiper blades that were nearly 2 years old - I bought them from my local dealership and have been impressed with no smearing and also no rumbling when the auto-on thinks I have a wet screen when it is quite dry! Problem now for me is how to replace the rear blade because try as I might I cannot get the rear wiper to park anywhere other than in the normal parked position............... which is darned hard to get at. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #513714 Fri Jan 06 2017 6:20pm
wilf
The only way I found to replace the rear wiper blade was to undo the nut on the spindle to allow the arm to drop down. You have to give it a tug to break the grip on the taper. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #513744 Fri Jan 06 2017 10:13pm
scrumps
Chaps,
Try this:-
http://www.rrsport.co.uk/forum/topic43174.html
Post #513754 Fri Jan 06 2017 11:22pm
wilf
I'd forgotten how to fo that, lol. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #513762 Sat Jan 07 2017 6:59am
PauloAmore
Scotland
Did you fit longer than OEM spec to get a wider wipe at the passenger side? There's an odd unwiped spot right n front of the passenger on mine. ... 2022 P440e AB
Post #513767 Sat Jan 07 2017 11:06am
BigBen
No just the standard sizes.[/quote]
Post #513787 Sat Jan 07 2017 6:33pm
kljw
Scotland
UPDATE
Hi
have just fitted the Bosch Wipers as recommended. not over impressed about having to buy my own when there is clearly and issue, but it seems to have resolved the problem, however they have only been on for a day....
Keith
Post #513834 Sun Jan 08 2017 9:25am
