Home > Maintenance & Modifications > autobox oil change |
RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51 |
If you just drain the oil by undoing the drain plug, only about a half (to a quarter) of the oil will come out. To completely drain it, the gearbox needs to be run and cycled through the gears. The spec for the ZF 6HP26 (as fitted to the 2.7 diesel), has a capacity of 9.5 litres.
Sat Oct 17 2015 5:42pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
It's fill to spill as long as it's at the correct temperature (and engine running, and you've cycled through the gear positions) - around 35 degrees is ideal IIRC. Around 5l is normal though.
Sat Oct 17 2015 5:43pm |
duncmc Member Since: 29 Sep 2015 Location: Warwickshire Posts: 21 |
RogerDeFlor, where did you get yours done? I want to get mine done and work in Gloucester half of the week. |
Sat Oct 17 2015 6:14pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
BlueIcePlus - if you are going to work on your own vehicle you need to read the workshop manual first so you know what you are doing. The way you are going about it you will do damage to your vehicle.
Sun Oct 18 2015 12:07am |
Pan and Filter Change: http://www.disco3.co.uk/gallery/albums/use...nstall.pdf
Sun Oct 18 2015 8:39am |
I used Tim Fry Landrovers in Cheltenham. They seem pretty good. |
Sun Oct 18 2015 1:28pm |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 |
I had a mega flush on the gearbox yesterday arranged by gilly, the mega flush removes all oil from gearbox and puts in about 11-12 litres |
Sun Oct 18 2015 1:48pm |
Thanks RogerDeFlor.
Sun Oct 18 2015 5:44pm |
