Home > Technical > Tyre and wheel arch contact when turning hard left |
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 |
Some updates.
Sat Aug 29 2015 8:54am |
Update2: It seems now that when I disable the traction control everything works fine! Still no fault codes. Somehow the car thinks it needs to cut power from the left front wheel when Im turning left.
Sat Aug 29 2015 5:55pm |
Thought there was a similar fault reported before; think it is this thread:
Sun Aug 30 2015 7:12pm |
Thanks Paddi!
Sun Aug 30 2015 7:17pm |
Good to hear you found the problem. Where did the metal particles come from - cutting off the lower arms to change them? 2008 MY Java Black TDV8 HSE
Mon Aug 31 2015 9:39am |
Im not really sure if its the dust from brake pads. Those lower arms came off easily so no cutting was needed. |
Mon Aug 31 2015 9:46am |
