Home > Technical > Installin 13-pin towing electrics from Bripart |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
I fitted a dual (7 & 13 pin) setup on mine (58-plate HST) (albeit from ebay).. didn't disconnect the battery. The hardest part for me was getting the wiring down behind the HST rear bumper... the rest was plain sailing.
Thu May 28 2015 12:18pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
Quite a good kit, just fitted one with no problems and I did not disconnect the battery, took longer to remove the panels than fit the kit, getting the wiring tidy was the hard part. Tail lights were also a bit of a pull to remove.
Thu May 28 2015 4:38pm |
You can have both pics and text...
Thu May 28 2015 4:40pm |
Nice one, wish I had seen this before I started, stuck my fuses behind the side panel ( not handy ) will need to move them now 😑 |
Thu May 28 2015 4:47pm |
As for the tail lights not being the easiest to pull out, I found that too, so used a smallish flat-blade screwdriver and a piece if tissue (to prevent scratching the paint) and "prised" them backwards from the small gap between the front of the unit and the rear 1/4 panel... doesn't take much to shift them this way and no damage done
Thu May 28 2015 4:51pm |
jorn Member Since: 07 Jan 2015 Location: Ypres Posts: 39 |
Thx for The info.
Thu May 28 2015 6:51pm |
I _think_ I removed both too mate.. IIRC, it was something to do with wiring up to the right-hand indicator.
Fri May 29 2015 10:21am |
Hi all
Fri May 29 2015 2:10pm |
