Home > Maintenance & Modifications > winter is here, drl's to be installed |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
excellent idea, thank you. I have my lights open still and I'll be getting this done during the week. top marks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Mon Feb 02 2015 1:52pm |
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 |
I got my originals from sparky on the forum but been having trouble with my near side headlight recently when it does the self levelling jig on start up it doesn't always come back up and stays facing down so got some more lights and Sparky hasn't got anymore so I've got the Dabhees version but might try removing the diffusers over the led's for a cleaner look.
Mon Feb 02 2015 6:47pm |
Hi all,
Sat Feb 07 2015 4:53pm |
On all the time and reduced brightness by about 40% with headlights on.... |
Sat Feb 07 2015 5:27pm |
that's gonna be difficult TrevG without some sort of resistor. My DRL's dim when the headlights are on so it would make sense. I'll wire them to the ignition live and then do some testing to see if they are too bright at night when the headlights are on. If they are, I'll have to make the change you suggest. Cheers. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sat Feb 07 2015 5:51pm |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
This thread along with watching some videos of disassembling headlights has given me the confidence to try this.
Sat Feb 14 2015 12:14pm |
Just a little update. The rings arrived and they turned out to be useless. Two of the led's on one ring stopped working after an hour. Simply wasn't confident in the other three after that. British quality at its finest. No wonder I outsource a load of my work further East. Anyway, I ordered then the dabhees rings and they are excellent quality. I took the reflectors off and wrapped them in carbon fibre film. End result:
Sat Feb 21 2015 9:18pm |
another one:
Sat Feb 21 2015 9:21pm |
....got mine from Dabhees. Haven't tested them yet but they look good.
Sat Feb 21 2015 9:43pm |
it's a job and a half, can't wait to get it finished. I'm painting the internals carbon black just to make it more difficult for myself Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sat Feb 21 2015 9:45pm |
....Plastikote primer and top coat?
Sat Feb 21 2015 9:49pm |
the lens was a pain in the rear end. heat gun and lots of patience. putting it back on is simple though
Sat Feb 21 2015 9:55pm |
I'm collecting all sorts.
Sat Feb 21 2015 10:15pm |
brilliant. i've connected the white and red wires from the rings to the live wire on the dimming module.
Sat Feb 21 2015 10:20pm |
