Home > Technical > Turbo blown |
engine-kid Member Since: 28 Aug 2013 Location: beverley Posts: 10 |
Hi all my 2007 hse 3.6v8 has blown turbo and won't start any ideas what else is wrong |
Wed Sep 25 2013 3:33pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
haven't you just bought this?
Wed Sep 25 2013 3:43pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
Bad news - Simple1 is sadly the expert on these
Wed Sep 25 2013 3:51pm |
We heard you the first time Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Sep 25 2013 4:45pm |
Wed Sep 25 2013 5:58pm |
Sorry to hear about your problem. If the engine turns over you may be able to save it. If it won't turn over the cylinder(s) may be full of oil and the engine is probably toast. Assuming engine is otherwise OK you will quickly find that fixing it is a major job and very expensive. The turbo is about a thousand pounds and replacement is a body off procedure about 7 hours labour in itself. It is essential to find and rectify the cause of the failure or the new turbo will go the same way. This can include replacing oil feed pipes and the intercooler. It would be false economy not to replace both turbos whilst the body is off. Unless all this work is done perfectly the problem will soon recur. Think your best option is return to seller for a full refund and second best is fix under warranty and then get rid. 2008 MY Java Black TDV8 HSE |
Fri Sep 27 2013 8:51am |
