Home > General > Rear interior lights |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Options are simple, either put up with the back of the car being dark or invest 90 minutes of your life and approx £2 and do the mod so that you/your kids can actually see what they are doing with their seat belts etc when they get into the car on these dark winter evenings or buy either a FFRR or Disco as both these cars have rear overhead courtesy lights...
Thu Jan 05 2012 10:30am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
it is quite shameful ============
Thu Jan 05 2012 3:51pm |
Ashie50 Member Since: 09 Jul 2015 Location: Worcestershire Posts: 1 |
Easy fix , I've tried getting prices from garages first but they just seemed to pull prices out the air . A very easy mod thanks for sharing |
Sun Feb 28 2016 11:33am |
EC Rover Member Since: 19 Sep 2017 Location: New Jersey Posts: 5 |
Simon1233, Did you use 2 diodes in this mod? I'm trying to convert the lights in my 2009 RRS and all this information is extremely helpful but although I do not have the experience of running wires I will still attempt to do this. I understand that you are running 1 wire down from each light (left & right) and then joining the other ends to the gray side of the diode and then splicing the other end into the wire from the cargo area light, but where is the other diode?
Tue Sep 19 2017 6:13pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
You use 1 diode for the left light
Tue Sep 19 2017 7:34pm |
Thanks AndyK.
Tue Sep 19 2017 8:42pm |
I think you better re read and I'll check when I get a moment, but.
Tue Sep 19 2017 8:49pm |
Ok, I have to look at that again then concerning B but what is wrong with F? |
Tue Sep 19 2017 9:23pm |
Just checked,
Tue Sep 19 2017 9:31pm |
duplicate |
Thanks for your help Andy. I will let you know how it turns out. I may not get to it as quickly as I'd like but I will definitely tell you after it's done. |
Tue Sep 19 2017 9:36pm |
you need to ensure the diode is fitted the correct way round.
Wed Sep 20 2017 12:12pm |
Pictures are in my gallery, links below
Thu Sep 21 2017 7:31pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Great guide Simon! Merc C220 estate Sport AMG
Fri Sep 22 2017 7:24am |
