Home > Technical > RRS RECALL 2006-2009 |
640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231 |
Is this just a UK/Europe problem or should I be raising it with my "trusty" Australian dealer?
Mon Nov 23 2009 11:57pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
640 - I believe the brake booster one was issued in Australia, before UK and Europe:
Tue Nov 24 2009 1:00am |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
Yep, sure is - I went through two pumps - both shot bearings. Sure makes a mess of the belt and the cover. Mine is a Oct 2005 RRS TDV6. Alto in Sydney know the procedure really well RRS TDV6 Bluetooth, VR, Roof |
Tue Nov 24 2009 10:53am |
Do you have a TSB number or a copy of the TSB for the recall Lateral? |
Tue Nov 24 2009 11:08am |
I don't Rower, I actually think mine helped kick off the recall. I took my car in to get the persistent transmission rasp noise attended too about 4-5 months back. They thought it was the high pressure fuel pump, so they replaced it and there started my problems. It blew through two replacement pumps and the guys at Alto showed me the unit - totally seized up bearing which stripped the belt and melted the belt cover - real mess. When I picked it up the third time, I was speaking with GAry at Alto and that's when he told me LR had started a recall - he had about 4500 cars to do! Ironically, there was nothing wrong with my original pump.... and the transmission noise is still there. LR have now said that is....."normal"....ie it is too expensive to fix or they don't know how. RRS TDV6 Bluetooth, VR, Roof |
Tue Nov 24 2009 11:20am |
Are you in Melb? If so, take it to Gary or Pete at MLR - they will know about it. If they don't ask them to call Gary at Alto Syd.....Gary to call Gary RRS TDV6 Bluetooth, VR, Roof
Tue Nov 24 2009 11:23am |
You obviously haven't seen my thread in the dealership feedback section Lateral.. I don't intend to return to Melbourne City Land Rover (MLR)
Tue Nov 24 2009 11:35am |
This continued over use of "it's normal" or "its characteristic" or "they all do that" as excuses by Land Rover Australia is ridiculous! |
Tue Nov 24 2009 11:39am |
I have had Lance Dixon check my VIN, and my car doesn't require the fuel pump recall.
Mon Nov 30 2009 12:34am |
