Home > General > EPB Fault again - Should this be a sticky as per D3
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
The EPB started screaming like a banshee again this morning, only shuts up if i release it again. That will be the fourth or is it fifth time is has been seen to, twice for the squealing, and about 2-3 times in terms of not fully releasing.
So it has to be parked on a reasonably flat service and left in Park only until thursday when the dealer gets it in
Have many others suffered from this, should we now put it as a sticky thread for known problems Question
Jim Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #169331 Mon May 12 2008 12:00pm
Tim in Scotland
My TDv6 suffered a lot from the screaching EPB but my TDv8 has not yet made a squeek (that's bound to make it start doing it!)
Zilch have you taken your RRS offroad because that is the only thing I can think of as to why my TDV8 doesn't scream, it hasn't yet been in the dirt unless LR have done a redesign of the system for more recent cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #169333 Mon May 12 2008 12:14pm
Zilch
Tim, it has not been off-road since the last service about 6 weeks ago, when the EPB was cleaned, lubricated and whatever they do to it to cure the notorious binding that occurs every time i release it. It had a complete EPB rebuild last year and that still did not totally cure it, only the banshee wail every time i engaged the thing. I think along with the D3's there must be an inherent design problem.
Post #169344 Mon May 12 2008 12:53pm
Zilch
Seems a well discussed topic on the D3 site http://www.disco3.co.uk/forum/topic14861.html
Post #169345 Mon May 12 2008 1:01pm
Ours has just started doing it today.
Always parked on flat driveway.
Could be to do with the very dusty climate over here... Runner up - 2009 Best Avatar Award Sad
Post #169383 Mon May 12 2008 6:45pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
mine started squeaking for a bit after the offraoding I done at the weekend, but I think it was more a case of the sand in the disks Shocked gave it a pull on at low speed and it has been quiet ever since ... touch wood.... Sons of dogs come hither and get flesh
Clan Cameron
Post #169392 Mon May 12 2008 8:18pm
Bobby
There is a TSB on "EPB Screech On Apply/Release When Stationary", issued early April. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #169428 Tue May 13 2008 9:08am
Zilch
Bobby can you post it
Thanks
Post #169440 Tue May 13 2008 10:07am
Bobby
the first page of the bulletin...
http://www.rrsport.co.uk/gallery/albums/us...se%7E0.pdf Malaysia Boleh!
Post #169547 Tue May 13 2008 11:46pm
Zilch
Bobby many thanks, be interesting to see whether they try charging me for the possible replacement pads due to excessive wear, due to Censored poor alignment. It is in again tomorrow.
Post #169569 Wed May 14 2008 8:07am
Zilch
UPDATE - EPB
Well the work was done at ALTO today, full clean and removal of dust build up, realignment, readjusted and SOFTWARE update to help cure it (not sure how it will cure dust build up). Apparently mine was the 3rd they had done that day at that dealer alone, so a common issue i would think.
Thanks Another Pommie Bar Steward down under
Post #169727 Thu May 15 2008 9:19am
Bobby
Hope your problem is solved! Thumbs Up Malaysia Boleh!
Post #169766 Thu May 15 2008 12:09pm
