| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > EPB Fault again - Should this be a sticky as per D3 |
| Zilch Joined: 20 Mar 2006 Location: way way down South.. Posts: 958
The EPB started screaming like a banshee again this morning, only shuts up if i release it again. That will be the fourth or is it fifth time is has been seen to, twice for the squealing, and about 2-3 times in terms of not fully releasing.
Seems a well discussed topic on the D3 site http://www.disco3.co.uk/forum/topic14861.html
| Supertrotter Joined: 10 Mar 2006 Location: Freezing my spuds off in Blighty (For a few weeks anyway!) Posts: 7298
Ours has just started doing it today.
| Alicatt Joined: 11 Jun 2007 Location: Eating in Eksel or Working in Wick Posts: 726
mine started squeaking for a bit after the offraoding I done at the weekend, but I think it was more a case of the sand in the disks |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1812
There is a TSB on "EPB Screech On Apply/Release When Stationary", issued early April. Malaysia Boleh!
the first page of the bulletin...
Bobby many thanks, be interesting to see whether they try charging me for the possible replacement pads due to excessive wear, due to piss poor alignment. It is in again tomorrow.
Well the work was done at ALTO today, full clean and removal of dust build up, realignment, readjusted and SOFTWARE update to help cure it (not sure how it will cure dust build up). Apparently mine was the 3rd they had done that day at that dealer alone, so a common issue i would think.
Hope your problem is solved! |
Staying - Epsom Green Defender 90 for playing off road
