Home > General > EPB Fault again - Should this be a sticky as per D3
Reply to topic  Down to end
Zilch
Australia 2006 Range Rover Sport TDV6 HSE Zermatt Silver
The EPB started screaming like a banshee again this morning, only shuts up if i release it again. That will be the fourth or is it fifth time is has been seen to, twice for the squealing, and about 2-3 times in terms of not fully releasing.
So it has to be parked on a reasonably flat service and left in Park only until thursday when the dealer gets it in
Have many others suffered from this, should we now put it as a sticky thread for known problems Question
Jim
_________________
yet another Pommie living in Sydney
2.7 RRS TDV6, Zermatt/Ebony moooo-hide, Clear pack, Cruise, Sunroof, tow pack, RPS, Tasmod Sills, RRS Umbrella, RRSPORT rear window sticker and last but not least a "Supercheap Auto" $20 cargo net "Marvellous" Thumbs Up
Post #169331 Mon May 12 2008 12:00pm
Tim in Scotland
My TDv6 suffered a lot from the screaching EPB but my TDv8 has not yet made a squeek (that's bound to make it start doing it!)
Zilch have you taken your RRS offroad because that is the only thing I can think of as to why my TDV8 doesn't scream, it hasn't yet been in the dirt unless LR have done a redesign of the system for more recent cars
_________________
A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
TDv8 HSE - Stornoway Grey with ebony and straight grain walnut wood-a-like interior with towpack, Tasmods. The best car I have ever owned
Now departed - Giverny Green TDv6SE with Aspen and Parchment interior - nearly the best car I have ever owned
Staying - Epsom Green Defender 90 for playing off road
Post #169333 Mon May 12 2008 12:14pm
Zilch
Tim, it has not been off-road since the last service about 6 weeks ago, when the EPB was cleaned, lubricated and whatever they do to it to cure the notorious binding that occurs every time i release it. It had a complete EPB rebuild last year and that still did not totally cure it, only the banshee wail every time i engaged the thing. I think along with the D3's there must be an inherent design problem.
Jim
_________________
Post #169344 Mon May 12 2008 12:53pm
Zilch
Seems a well discussed topic on the D3 site http://www.disco3.co.uk/forum/topic14861.html
Jim
_________________
Post #169345 Mon May 12 2008 1:01pm
Cyprus 2006 Range Rover Sport TDV6 HSE Java Black
Ours has just started doing it today.
Always parked on flat driveway.
Could be to do with the very dusty climate over here...
_________________
06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
COME TO TROTTERLAND
http://trotterland.myminicity.com
HELP BUILD ROADS IN TROTTERLAND
http://trotterland.myminicity.com/tra
HELP JOBS IN TROTTERLAND
http://trotterland.myminicity.com/ind
Post #169383 Mon May 12 2008 6:45pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
mine started squeaking for a bit after the offraoding I done at the weekend, but I think it was more a case of the sand in the disks Shocked gave it a pull on at low speed and it has been quiet ever since ... touch wood....
_________________
Sons of dogs come eat flesh
Clan Cameron
Post #169392 Mon May 12 2008 8:18pm
Bobby
There is a TSB on "EPB Screech On Apply/Release When Stationary", issued early April.
_________________
Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #169428 Tue May 13 2008 9:08am
Zilch
Bobby can you post it
Thanks
Jim
_________________
Post #169440 Tue May 13 2008 10:07am
Bobby
the first page of the bulletin...
http://www.rrsport.co.uk/gallery/albums/us...se%7E0.pdf
_________________
Malaysia Boleh!
Post #169547 Tue May 13 2008 11:46pm
Zilch
Bobby many thanks, be interesting to see whether they try charging me for the possible replacement pads due to excessive wear, due to piss poor alignment. It is in again tomorrow.
Jim
_________________
Post #169569 Wed May 14 2008 8:07am
Zilch
UPDATE - EPB
Well the work was done at ALTO today, full clean and removal of dust build up, realignment, readjusted and SOFTWARE update to help cure it (not sure how it will cure dust build up). Apparently mine was the 3rd they had done that day at that dealer alone, so a common issue i would think.
Thanks
_________________
Post #169727 Thu May 15 2008 9:19am
Bobby
Hope your problem is solved! Thumbs Up
_________________
Malaysia Boleh!
Post #169766 Thu May 15 2008 12:09pm
Reply to topic  Back to top
Site Copyright © 2005-2008 Martin Lewis
