Home > Technical > Rear passenger door won't open!
j8keyboy
My n/s rear passenger door won't open and was wondering whether anyone has had this issue before or know what I should do? When I press the key fob the door handle lock button moves slightly but not all the way to the open posistion like the other doors.
Thanks,
J8keyboy 2005 55 TDV6 HSE, JAVA BLACK, FACTORY PRIVACY GLASS, SIDE STEPS, OVERFINCH SUPERSPORT 22S, COLOUR CODED GRILL & VENTS, CHROME MIRRORS, CLEAR REPEATERS, BLACK LR BADGES
Post #169593 Wed May 14 2008 9:47am
MAW
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Does it make a difference if you use the dashboard lock unlock to toggle it?
Can you manually unlock and open it?
Have you done a manual unlock open close to see if anything ;gets better' ? This kind of reset may sort it if it'll work...
Let us know
Post #169597 Wed May 14 2008 9:54am
j8keyboy
The dashboard lock unlock makes no difference.
It's the n/s rear passenger door so no key lock.
I will try a manual unlock open close.
Thanks,
Jake 2005 55 TDV6 HSE, JAVA BLACK, FACTORY PRIVACY GLASS, SIDE STEPS, OVERFINCH SUPERSPORT 22S, COLOUR CODED GRILL & VENTS, CHROME MIRRORS, CLEAR REPEATERS, BLACK LR BADGES
Post #169603 Wed May 14 2008 10:30am
MAW
Understand no key lock was thinking from inside - good luck...
Post #169609 Wed May 14 2008 10:55am
Tim in Scotland
Have you tried the emergency manual lock on the front passenger door - you remove the cover with the little key icon on it and insert the ignition key to manually operate all the locks. There is a section about it in the manual, sorry I cannot tell you which page as I am a long way from my car at the moment. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #169611 Wed May 14 2008 11:00am
BoatMad
Ireland 2007 Range Rover Sport TDV8 HSE Java Black
I've have this problem as well on the rear left hand side door, manual lock only moves slightly when you askl for an unlock. Its looks like a sticking lock motor to me. It suddenly started workng again recently but its in for a service soon and a replacement lock motor
also my right rear door headset control panel failed
1 year old 66Km's RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Previously FFRR TD6 Metallic Grey
Post #169865 Fri May 16 2008 6:49pm
