| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Rear passenger door won't open! |
| j8keyboy Joined: 09 Oct 2007 Location: Loughborough Posts: 31
My n/s rear passenger door won't open and was wondering whether anyone has had this issue before or know what I should do? When I press the key fob the door handle lock button moves slightly but not all the way to the open posistion like the other doors.
| MAW Joined: 06 May 2006 Location: Lincs Posts: 801
Does it make a difference if you use the dashboard lock unlock to toggle it?
The dashboard lock unlock makes no difference.
Understand no key lock was thinking from inside - good luck... |
| BoatMad Joined: 11 Feb 2007 Location: Dublin Posts: 62
I've have this problem as well on the rear left hand side door, manual lock only moves slightly when you askl for an unlock. Its looks like a sticking lock motor to me. It suddenly started workng again recently but its in for a service soon and a replacement lock motor
Staying - Epsom Green Defender 90 for playing off road
