Home > Maintenance & Modifications > Badge Help Please
RAL1975
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Badge Help Please
Hi, this is my first post since getting my RRS HSE a couple of weeks ago. Have managed to obtain info from other threads on upgrading most badges to S/C version, however have seen no advice on how to remove rear badge.
Also, some re-confirmed advice on wheel cap centres would also be much appreciated.
Thanks
Post #129391 Thu Aug 02 2007 10:09pm
William
Qatar 2007 Range Rover Sport 4.4 V8 HSE Buckingham Blue
Welcome to the forum mate and congratualtions on your new purchase (you won't regret it Confused ... I think)
As to the Rear badge, I removed mine by hand using merely my fingers. Other owners used smthg
like a dental floss or fishing Nylon rope to slice the sticky foam and release the green badge.
Afterwards you'll need to remove the residual sticky foam and render the paint clean and ready
to paste the Black/Silver one. For that I used a dry towel, slowly and VERY carefully I started scratching
the foam off (bit by bit). I felt the paint behind the badge got slightly damaged (lost its shine) but
that was not a problem since the new badge will cover that area anyway.
As to the wheel cap centers. I recommend taking the wheels out to remove them.
Otherwise, you risk breaking a clip or two (which is OK if you do not care to keep the old ones).
Alternatively, you can drill through the caps and pull them out to be replaced with the Black ones.
Hope this helps.
William RRS 2007 HSE V8 * Buckingham Blue * Ebony Leather * Cooler Box * Sunroof * Navigation * PTI Bluetooth * Side Steps * Mud Flaps * Body Side Mouldings * V-Kool V70 Heat Insulation Glass Film * Clear Side Repeaters * Color-coded Side Vents + Grille + Door Handles + Door Mirrors * S/C Rear Decals + Door & Steering Emblems * S/C Exhaust Catbacks * Tasmod Sills * Nokia Cradle + Phone * 22" Stormers * 1st Edition Badge Very Happy
New Pics: http://www.rrsport.co.uk/gallery/index.php?cat=11210
Post #129429 Thu Aug 02 2007 11:24pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
boiling water on the badges that will soften the adhesive, then just pull them off, as for the wheel centres, i use a sharp point and flicked them out Thumbs Up some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #129456 Thu Aug 02 2007 11:49pm
RAL1975
Thanks William and Envoy - much appreciated advice.
Post #129537 Fri Aug 03 2007 2:31pm
kam100
Hair dryer on the badge, melts the black adhesive and the badge just drops off, or will light persuasion anyway.
The black residue, now thats more tricky. I found recently when debadging a different car, the black stuff was hard to remove, but with constant hair drying (heating it up) and rubbing it with a towel, it came off gradually, and i polished over it with some good wax, and its as good as new, no paint damage no nothing.. Your neighbours look at you a bit funny, wondering if your actually drying your car by hand using a hair dryer, but sod em, they wouldn't understand anyway!!
Post #129539 Fri Aug 03 2007 2:38pm
There is that stuff that you can buy from your local hardware shop/Robert Dyas or whatever that's used for removing chewing gum etc - that works well on that sort of stuff.
Post #129542 Fri Aug 03 2007 3:19pm
kam100
I would just be worried on using any checmical or anything on the car, in case it made the shine go or worse take a layer of the mettallic paint off!! stick to a hair dryer and towel i think..
Post #129548 Fri Aug 03 2007 3:59pm
Endjin
Scotland
Mine took no chemicals or fishing gut etc. to cut sticky pad. Simply get fingernails under one edge and then VERY slowly start to apply pressure away from car body. The sticky pad will start to peel away from paint - keep an even pressure and do not be tempted to go quickly. keep it very slow and it will just come away. I didn't even have a mark left when mine came off! Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #129624 Fri Aug 03 2007 9:35pm
Glynn
Guys - this is my first post (have been lurking since May!).
Just taken the rear badge off. Used hairdryer and credit card to lift the badge, then Autoglym Intensive Tar Remover, credit card and cloth to gently remove the residue adhesive. 15 minute job and perfect result. Now to stick the black one on!
Post #129705 Sat Aug 04 2007 11:41am
Tay_pt
Portugal 2006 Range Rover Sport TDV6 HSE Java Black
On my last visit to the dealer, I ask them to take out the HSE lettering, thinking they would certainly do it better. The result was good, but not completely perfect. With sunshine you can slightly notice that something was scrub there.When I replace the LR badge… I definitely will do it my self.
BTW… can some one tell me what the ‘Supercharged’ badge dimensions are?
Thanks
Post #130190 Mon Aug 06 2007 6:01pm
davidbrown
United States
you can also use petrol in removing residue lest by the adhesive.
Land rover aftermarket parts.
Post #130625 Wed Aug 08 2007 9:14am
