![]() | Home > Maintenance & Modifications > Badge Help Please |
| William Member Since: 08 Apr 2007 Location: Doha Posts: 113
Welcome to the forum mate and congratualtions on your new purchase (you won't regret it |
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823
boiling water on the badges that will soften the adhesive, then just pull them off, as for the wheel centres, i use a sharp point and flicked them out |
| RAL1975 Member Since: 25 Jul 2007 Location: BRISTOL Posts: 2
Thanks William and Envoy - much appreciated advice. |
| kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771
Hair dryer on the badge, melts the black adhesive and the badge just drops off, or will light persuasion anyway.
I would just be worried on using any checmical or anything on the car, in case it made the shine go or worse take a layer of the mettallic paint off!! stick to a hair dryer and towel i think.. |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
Mine took no chemicals or fishing gut etc. to cut sticky pad. Simply get fingernails under one edge and then VERY slowly start to apply pressure away from car body. The sticky pad will start to peel away from paint - keep an even pressure and do not be tempted to go quickly. keep it very slow and it will just come away. I didn't even have a mark left when mine came off! |
| Glynn Member Since: 07 May 2007 Location: Ringwood, Hants Posts: 1
Guys - this is my first post (have been lurking since May!).
| Tay_pt Member Since: 16 Mar 2007 Location: Porto Posts: 55
On my last visit to the dealer, I ask them to take out the HSE lettering, thinking they would certainly do it better. The result was good, but not completely perfect. With sunshine you can slightly notice that something was scrub there.When I replace the LR badge… I definitely will do it my self.
| davidbrown Member Since: 08 Aug 2007 Location: Beside my dream Rover Posts: 11
you can also use petrol in removing residue lest by the adhesive. |
