Home > General (L494) > Anyone had a C1043 1C error causing terrain response issues?
Karlp606
After fixing my leaking ace pipes I’m now getting the yellow lean error and an error code of C1043 1C which is the rear axle pressure ? Code won’t clear and also all terrain response / dynamic driving is unavailable??
Post #649426 Wed Aug 13 2025 6:07pm
Ade RRS
Yes I have the same issue, I haven’t managed to resolve this yet.
Have you made any progress?
Thanks
Post #649831 Tue Sep 16 2025 4:46pm
Karlp606
Hi yes its the rear axle sway pressure - you need to check your hydraulic pipes if there is any leak - if there isnt check your fluids - and if your still getting the warning your solenoid is probably shot on the ace block - you can try to take it out and refurb it - or buy a new one.
I bought a second hand one from ebay with warranty to solve my issue - I have my old block that Im taking apart and will refurb the bad solenoid. -
Post #649843 Wed Sep 17 2025 11:27am
Ade RRS
Thanks
Dumb Q what and where is the Ace block please?
Post #649855 Thu Sep 18 2025 9:46am
Karlp606
So the ace block is just sort of under the passenger door under the car - if you search my profile I’ve done some threads on it - there’s 4 pipes that goto the ace block that run the dynamic system on the roll bars 2 front 2 rear - you’ll either have a leaking pipe that can be repaired or the block as gone bad.
You need to get under the car and pop the plastic under tray off sort of behind the passenger wheel and check if there’s a leak - or any fluid around your car - ans check the hydraulic fluid reservoir in your engine bay Thumbs Up
Post #649856 Thu Sep 18 2025 10:25am
Ade RRS
Thank you, do you have the part number for the block please?
Post #650106 Mon Oct 06 2025 11:29am
Karlp606
Here you go pal;
https://www.ebay.co.uk/itm/386806423955?ch...gJmKvD_BwE
I have a spare 2nd hand one that needs refurbing its the rear bar solenoid thats not activating just requires cleaning out from the block.
Post #650123 Wed Oct 08 2025 5:40pm
Ade RRS
Thanks Mate
Post #650124 Wed Oct 08 2025 6:48pm
