![]() | Home > General (L494) > Anyone had a C1043 1C error causing terrain response issues? |
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13
Yes I have the same issue, I haven’t managed to resolve this yet.
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 322 |
Hi yes its the rear axle sway pressure - you need to check your hydraulic pipes if there is any leak - if there isnt check your fluids - and if your still getting the warning your solenoid is probably shot on the ace block - you can try to take it out and refurb it - or buy a new one.
Thanks
So the ace block is just sort of under the passenger door under the car - if you search my profile I’ve done some threads on it - there’s 4 pipes that goto the ace block that run the dynamic system on the roll bars 2 front 2 rear - you’ll either have a leaking pipe that can be repaired or the block as gone bad.
Thank you, do you have the part number for the block please? |
Here you go pal;
Thanks Mate |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23 |
Ive got a similar but different error C104A - front axle piston regulating valve.
Is the ace block the same as the ace valve? |
Ace block / valve yes same thing .
| All times are GMT |
