| RRSPORT.CO.UK | ||
|  | Home > General (L494) > Anyone had a C1043 1C error causing terrain response issues? |
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13    | Yes I have the same issue, I haven’t managed to resolve this yet.
|  Tue Sep 16 2025 3:46pm |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Hi yes its the rear axle sway pressure - you need to check your hydraulic pipes if there is any leak - if there isnt check your fluids - and if your still getting the warning your solenoid is probably shot on the ace block - you can try to take it out and refurb it - or buy a new one.
|  Wed Sep 17 2025 10:27am |
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13    | Thanks
|  Thu Sep 18 2025 8:46am |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | So the ace block is just sort of under the passenger door under the car - if you search my profile I’ve done some threads on it - there’s 4 pipes that goto the ace block that run the dynamic system on the roll bars 2 front 2 rear - you’ll either have a leaking pipe that can be repaired or the block as gone bad.
|  Thu Sep 18 2025 9:25am |
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13    | Thank you, do you have the part number for the block please? | ||
|  Mon Oct 06 2025 10:29am |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Here you go pal;
|  Wed Oct 08 2025 4:40pm |
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13    | Thanks Mate | ||
|  Wed Oct 08 2025 5:48pm |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Ive got a similar but different error C104A - front axle piston regulating valve.
|  Mon Oct 13 2025 6:29pm |
 Is the ace block the same as the ace valve? | ||
|  Mon Oct 13 2025 6:30pm |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Ace block / valve yes same thing .
|  Mon Oct 13 2025 6:48pm |
| Posting Rules
