Home > General > Fuel tank support
Page 2 of 3 <123>
Ironhorse
just done one on the wife's Evoque, hope the L494 is a bit easier to do
4.5 hours to get the diff hanger bolts out to drop the tank Big Cry 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #648991 Mon Jul 21 2025 5:03pm
41jules1967
Afraid not.
Exhaust off, propshaft off and lots of other bolts to remove. 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #648993 Mon Jul 21 2025 6:31pm
Ironhorse
Lol
Look forward to that job then 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #648994 Mon Jul 21 2025 6:46pm
41jules1967
Yeah.
I’d been hoping to put a Saturday aside, drop it, coat it in hammerite as a pre-emptive measure and pop it back.
From what I can tell it requires specialist tools and more stripping down than I’d attempt on the driveway.
One guy reckoned 8 hours with a ramp. 2021 L494 D300MHEV Autobiography
Post #648999 Tue Jul 22 2025 9:30am
spray oil between the tank and support.
Coat the underside with used oil
Post #649001 Tue Jul 22 2025 10:36am
41jules1967
I might look into lanoguard if there's enough access to spray it on top of the panel below the tank. 2021 L494 D300MHEV Autobiography
Post #649003 Tue Jul 22 2025 12:49pm
Meshan
Lanoguard is great.
Your car smells like sheep L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #649032 Wed Jul 23 2025 2:38pm
Grimble
Just got an advisory on my MOT regarding corrosion on this item. Is it just a 'cover' or is it critical to the support of the fuel tank? RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #649064 Thu Jul 24 2025 3:51pm
41jules1967
Critical I believe.
The videos I’ve seen of replacement show the support and tank being removed as a single unit so I assume that’s all that holds the tank to the car. 2021 L494 D300MHEV Autobiography
Post #649067 Thu Jul 24 2025 6:49pm
Disco_Mikey
Yes, the cover holds the tank in place
Post #649068 Thu Jul 24 2025 7:49pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Mine is rotten too, 2013 5.0 ltr..
car was in for some work 8 months ago and tray was put on back order, still waiting.
I honestly believe they make it unavailable thinking it will sway customers to trade in for a new model!
Post #649107 Sat Jul 26 2025 8:07pm
Grimble
Got under the car to replace the fail item, a lower suspension arm dust cover, and had a look at the tank covers. Surface rust only, hardly worth an advisory.
No way I'm removing them, however a bit of protection can never go amiss.
Bearing in mind its accessible on one side only, any suggestions as to the best treatment?
Note also this will be done with me on my back. RRS HSE Dynamic SDV6 2014
Post #649143 Tue Jul 29 2025 11:40am
Ironhorse
Do all my cars with lanoguard to be fair, easy to apply ,turns any rust black after a few days
wear a mask as it doesn’t taste that good. 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649146 Tue Jul 29 2025 2:49pm
Ironhorse
Suspension on high and on a couple of sleepers ,dont forgot axle stands
Plenty of room 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649147 Tue Jul 29 2025 2:59pm
Grimble
Cheers, do you know if it can be applied via a garden sprayer? The type you pump up and use on weeds etc? RRS HSE Dynamic SDV6 2014
Post #649148 Tue Jul 29 2025 3:25pm
Page 2 of 3 <123>
