![]() | Home > General > Fuel tank support |
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 112 ![]() ![]() |
Afraid not.
Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 31 ![]() ![]() |
Lol
Yeah.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5120 ![]() ![]() ![]() |
spray oil between the tank and support.
I might look into lanoguard if there's enough access to spray it on top of the panel below the tank. 2021 L494 D300MHEV Autobiography
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 91 ![]() ![]() ![]() |
Lanoguard is great.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 274 ![]() ![]() |
Just got an advisory on my MOT regarding corrosion on this item. Is it just a 'cover' or is it critical to the support of the fuel tank? RRS HSE Dynamic SDV6 2014
Critical I believe.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Yes, the cover holds the tank in place |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 249 ![]() ![]() ![]() |
Mine is rotten too, 2013 5.0 ltr..
Got under the car to replace the fail item, a lower suspension arm dust cover, and had a look at the tank covers. Surface rust only, hardly worth an advisory.
Do all my cars with lanoguard to be fair, easy to apply ,turns any rust black after a few days
Cheers, do you know if it can be applied via a garden sprayer? The type you pump up and use on weeds etc? RRS HSE Dynamic SDV6 2014
