![]() | Home > General (L494) > ACE Leak passenger side ... Hot Weather? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Nope. It'll be rotten pipes... |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 318 ![]() |
Urgh! Hoping you wasn’t going to say that Mikey lol
If you take the 10mm bolts out the inside edge of the panel and pull it down, you should see where it's coming from
Yes it’s dripping through one of the plastic pop rivets on the plastic sill about 6 inches back from the wheel arch.
Just checking, is the valve block/pump on the passenger side about 6 inches back where all the pipes feed into??
Photos - I seem to have 3 drips -
Yes, that's about where the valve block is. Look for wet and rusty pipes |
Thanks Mikey - gonna check it on my friends ramps on Tuesday hopefully.
Thankfully, the L494 valve blocks do not suffer from corrosion in the same way the L320 does |
Got to the pipe and pretty conclusive!
What condition are the rest of the pipes in? Usually replacing a single section is false economy... |
The other pipes were pretty clean and not corroded like the leaking one, after I cleaned them up.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427 ![]() ![]() ![]() |
I'm just glad that I live in an environment where it doesn't rain very much and corrosion is not a problem. After 15 years, I don't have a spot of corrosion on anything, even the bolts underneath are rust free.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
I inclined to think the major cause of corrosion with the pipes etc. is actually the salt used on UK roads during the winter months more than just a wet climate, they don't salt the roads here either so very little rust on my old L320 over and above what was there previous to shipping it here from the UK at three years old.
