Home > General (L494) > ACE Leak passenger side ... Hot Weather?
Karlp606
New pipe on last night , just need to get it into valve block and put 2 new studs in - if anyone attempts this be very careful when removing the 2 nuts that hold the valve cover onto the block as one of my studs snapped , luckily I could get some grips on it and twist it out - otherwise you need to drill the stud out the valve block.
Pretty easy job to be far hardest part is trying to get the plastic trim off that covers the pipes if the nuts are seized on as the plastic cover doesn't drop down enough to get a ratchet and spanners in when tightening the compression joint so space is tight if your not using a ramp- here is the ebay link I used;
https://www.ebay.co.uk/itm/267039668354?ch...gLTc_D_BwE
Guy is a Land Rover nut/mechanic who came up with the pipe , very very helpful and helped me over whats app also. Can highly recommend.
Post #648696 Fri Jul 04 2025 10:05am
Karlp606
Couple photos of the studs to be careful of on the cover .
PS forgot to add going to paint the pipes with some outdoor metal paint to give them extra protection.
Post #648697 Fri Jul 04 2025 10:18am
