Home > Wheels & Tyres > Will a 2006 RR Sport spare fit a 2012 RR Sport?
CarbonTrac
Hi All,
My 2012 RR Sport spare wheel is knackered (corroded) and won’t hold air. I’ve found someone local selling a spare from a 2006 - will it fit?
Mine - 175/80/19
Potential Purchase - 255/50/19
Will I have any issues or will it do the job and get me off the motorway in an emergency? I suppose also, will it fit under the car as well?
Thanks All.
Post #648111 Thu May 22 2025 6:14pm
It will fit the car as the PCD is the same on both vehicles, and will certainly fit under the vehicle, what size wheel/tyres are fitted to the car? as if to much of a mismatch might throw up a warning light/fault code on the likes of roundabouts etc.
Post #648114 Thu May 22 2025 10:23pm
CarbonTrac
Hi Col,
Thanks as always for coming to the rescue.
It’s currently running 275/40/20.
Many thanks!
Post #648115 Thu May 22 2025 10:31pm
The 255 is around 10mm larger diam. probably less if a worn tyre, so should be no problem as a spare to get you home ok.
Post #648118 Thu May 22 2025 10:46pm
CarbonTrac
Thanks so much for your help, much appreciated, as always.
Post #648119 Thu May 22 2025 10:49pm
