![]() | Home > Wheels & Tyres > Will a 2006 RR Sport spare fit a 2012 RR Sport? |
It will fit the car as the PCD is the same on both vehicles, and will certainly fit under the vehicle, what size wheel/tyres are fitted to the car? as if to much of a mismatch might throw up a warning light/fault code on the likes of roundabouts etc.
CarbonTrac Member Since: 05 Jun 2018 Location: Leicestershire Posts: 38 ![]() ![]() ![]() |
Hi Col,
The 255 is around 10mm larger diam. probably less if a worn tyre, so should be no problem as a spare to get you home ok.
Thanks so much for your help, much appreciated, as always. |
