![]() | Home > Technical > Strange Fault - Forward Looking Sensor - C1A67-78 |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
It must have had a good whack then, as the bracket sits within the crash bar and the radar sensor only slightly protrudes out of the crash bar.
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 261 ![]() ![]() |
My RRS has never been hit in the bumper therefor the bracket cannot be bent 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
There is a special JLR tool to align the bracket (a bit like a spirt level) as : -
I have not had any errors saying the sensor is blocked. Just the fault listed below indicating out of alignment. I have a Gap ID Tool, I wonder if there is a recalibration process I could try? I don’t trust the dealer to remove the bumper without damaging anything I assume it would be a dead end seeing as my RRS has never been hit. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
I don't think there is anything on the IID to calibrate the sensor, Pathfinder will calibrate it with a drive cycle but that fault is saying it's too far out for a software calibration.
Thanks for sending the PDF. It references the bracket being pushed out of alignment at low speed, had I hit something or something hit me then I would 100% think it is that. However, that hasn't happened.
Was it ok before it went in for service? Bottom line in my mind is; if it was ok before the service and then the problem appeared after the service, or whilst in service - then it's their problem.
Code happened before the service, I thought it was a one off so I cleared it with Gap ID tool. Then they flagged it as a fault during service, I had it happen again on the drive home. Appears to be permanent as this point. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Does anyone know if you can reach the plug for the radar module behind the front bumper if you remove the grill and reach down? 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
No it's not possible as the unit is recessed into the crashshbar and has to be removed to even see the plug. |
