| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Strange noise possibly coming from compressor ? |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | Your right that’s the air compressor for the suspension. Need more info on the noise though. Is it something you’ve not heard before or your just getting round to it. Does the suspension perform ok in its functions and does it sit well? I get an occasional dump valve puff (only the one) but I don’t hear any noise from mine, but then I’m in the car when it’s being lowered or raised to get the dogs in. Others will be along today. Forget the gearbox oil, you be changing the compressor  | ||
|  Thu Sep 29 2022 6:40am |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Hi, thanks for reply.
|  Thu Sep 29 2022 6:53am |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Update
|  Thu Sep 29 2022 10:23am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | Its generally ok if it comes on at start up. It’s possible there is a small leak.
|  Thu Sep 29 2022 11:28am |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | I have some more info on this….
|  Thu Sep 29 2022 12:19pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Also heard someone say turn engine on and then do a complete wheel lock turn to wheel lock turn and this resets the air suspension ? | ||
|  Thu Sep 29 2022 3:02pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | I don’t think any of that is going to help you. | ||
|  Thu Sep 29 2022 6:27pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Steering lock to lock resets suspension, not sure who dreamt that one up.   | ||
|  Thu Sep 29 2022 7:04pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | So yeah compressor not come on today at all so that’s good. I’ve been thinking my drive slips to one side as it’s not the levelest. I’m guessing overnight the RRS will try to level itself out to the lowest axel point and so when I switch it in in the morning the compressor is needed.
|  Fri Sep 30 2022 5:52pm |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563      | That's what RRSs will do to you. You'll be driving along listening for the next problem. And so any slight tinkling or different road noise will have you crawling underneath or reaching for the phone. I remember seeing one comment on here from from and "old hand" (I guess). He said if you hear a noise just turn up the stereo. Whilst I don't necessarily follow this advice to the letter, it does help to balance out my concern about reaching for the cheque book versus enjoying the drive.[/s] Robin
|  Sat Oct 01 2022 2:50pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
 as far as new compressor fitted, there are some crap Chinese one's out there that last as long as it takes to fit them, hopefully it hasn't had one of those fitted. I think you may be worrying about nothing If everything works as should and nothing showing on 4x4 screen I would just keep it under observation to see if it get's worse.
