![]() | Home > Faults & Fixes > Strange noise possibly coming from compressor ? |
Your right that’s the air compressor for the suspension. Need more info on the noise though. Is it something you’ve not heard before or your just getting round to it. Does the suspension perform ok in its functions and does it sit well? I get an occasional dump valve puff (only the one) but I don’t hear any noise from mine, but then I’m in the car when it’s being lowered or raised to get the dogs in. Others will be along today. Forget the gearbox oil, you be changing the compressor |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122 ![]() ![]() ![]() |
Hi, thanks for reply.
Update
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5086 ![]() ![]() ![]() |
Its generally ok if it comes on at start up. It’s possible there is a small leak.
I have some more info on this….
Also heard someone say turn engine on and then do a complete wheel lock turn to wheel lock turn and this resets the air suspension ? |
I don’t think any of that is going to help you. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Steering lock to lock resets suspension, not sure who dreamt that one up. |
So yeah compressor not come on today at all so that’s good. I’ve been thinking my drive slips to one side as it’s not the levelest. I’m guessing overnight the RRS will try to level itself out to the lowest axel point and so when I switch it in in the morning the compressor is needed.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1548 ![]() ![]() ![]() |
That's what RRSs will do to you. You'll be driving along listening for the next problem. And so any slight tinkling or different road noise will have you crawling underneath or reaching for the phone. I remember seeing one comment on here from from and "old hand" (I guess). He said if you hear a noise just turn up the stereo. Whilst I don't necessarily follow this advice to the letter, it does help to balance out my concern about reaching for the cheque book versus enjoying the drive.[/s] Robin
