| RRSPORT.CO.UK | ||
|  | Home > General > help and advice needed |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Check cam sensor plugged in on passenger side head at front
|  Mon Apr 18 2022 10:02pm |
| Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14      | thank you is it worth replacing cam sensor while at it ? | ||
|  Mon Apr 18 2022 10:05pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | No. Unless there is a fault code.
|  Tue Apr 19 2022 8:34am |
| Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14      | Getting zero fuel at injectors | ||
|  Tue Apr 19 2022 9:13am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | At the metal pipes ?
|  Tue Apr 19 2022 9:37am |
| Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14      | correct 1 pipe removed and zero fuel comes through it plenty through at low pressure and bled through easily but nothing at high pressure with 2 different pumps. I am lost with it | ||
|  Tue Apr 19 2022 10:31pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Read fault codes is next sensible thing | ||
|  Wed Apr 20 2022 2:19am |
| Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14      | no fault codes at all with specialist rr reader. But another question as i said i bought replacement cams but am now
|  Mon Apr 25 2022 10:18pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
