Home > General > help and advice needed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4794 |
Check cam sensor plugged in on passenger side head at front
Mon Apr 18 2022 11:02pm |
Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14 |
thank you is it worth replacing cam sensor while at it ? |
Mon Apr 18 2022 11:05pm |
No. Unless there is a fault code.
Tue Apr 19 2022 9:34am |
Getting zero fuel at injectors |
Tue Apr 19 2022 10:13am |
At the metal pipes ?
Tue Apr 19 2022 10:37am |
correct 1 pipe removed and zero fuel comes through it plenty through at low pressure and bled through easily but nothing at high pressure with 2 different pumps. I am lost with it |
Tue Apr 19 2022 11:31pm |
Read fault codes is next sensible thing |
Wed Apr 20 2022 3:19am |
no fault codes at all with specialist rr reader. But another question as i said i bought replacement cams but am now
Mon Apr 25 2022 11:18pm |
