Home > Maintenance & Modifications > RRS L320 2013 coolant expansion tank replacement |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Well, to be honest, it should take no more than 5 mins to remove the headlight so you have nothing to lose either way. 2010 RRS, TDV8
Mon Jul 19 2021 4:15pm |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Hi gogsy yes true I will have a look the dreaded float issue it only happens now and again then clears itself but have the new tank to go in . |
Mon Jul 19 2021 4:58pm |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
Mine needs doing too, im going to order one this week |
Sun Sep 12 2021 6:23pm |
Hi did mine found it easier taking front grill off and RH headlight unit out was easier getting to bottom pipe |
Sun Sep 12 2021 7:25pm |
colino Member Since: 02 Mar 2014 Location: Wentworth Falls Posts: 4 |
Hi,
Fri Aug 25 2023 9:07am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
David did one: Regards etc.,
Fri Aug 25 2023 6:00pm |
Hi Wokek,
Fri Aug 25 2023 11:41pm |
Oh, OK, I see now. Yes, I believe removing the headlight (takes some 30 seconds if some WD40 is necessary) and working from the bottom of the tank would be the best way. Just give it a shot. Regards etc.,
Sat Aug 26 2023 10:34am |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 95 |
I'm tackling this job tomorrow, was going to remove the light and grill as it looks like and space gain will be helpful.....
Sat Aug 26 2023 8:54pm |
Hi All
Mon Aug 28 2023 7:50pm |
Great to hear it, and how did you tackle the bottom hose? Regards etc.,
Tue Aug 29 2023 8:11am |
The bottom hose was the one I thought was going to be the really difficult part of the job.
Tue Aug 29 2023 4:42pm |
Difficulty scale, 1-10? Regards etc.,
Tue Aug 29 2023 7:03pm |
in my view its probably a 3
Wed Aug 30 2023 8:50am |
