![]() | Home > Maintenance & Modifications > RRS L320 2013 coolant expansion tank replacement |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Well, to be honest, it should take no more than 5 mins to remove the headlight so you have nothing to lose either way. 2010 RRS, TDV8
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi gogsy yes true I will have a look the dreaded float issue it only happens now and again then clears itself but have the new tank to go in . |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
Mine needs doing too, im going to order one this week |
Hi did mine found it easier taking front grill off and RH headlight unit out was easier getting to bottom pipe |
colino Member Since: 02 Mar 2014 Location: Wentworth Falls Posts: 4 ![]() ![]() ![]() |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
David did one: Regards etc.,
Hi Wokek,
Oh, OK, I see now. Yes, I believe removing the headlight (takes some 30 seconds if some WD40 is necessary) and working from the bottom of the tank would be the best way. Just give it a shot. Regards etc.,
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 182 ![]() ![]() ![]() |
I'm tackling this job tomorrow, was going to remove the light and grill as it looks like and space gain will be helpful.....
Hi All
Great to hear it, and how did you tackle the bottom hose? Regards etc.,
The bottom hose was the one I thought was going to be the really difficult part of the job.
Difficulty scale, 1-10? Regards etc.,
in my view its probably a 3
