Home > Maintenance & Modifications > RRS L320 2013 coolant expansion tank replacement
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi just wanted to confirm if it’s easier to remove passenger side headlight to give better access to hoses that connect to coolant expansion tank. Question Question thanks Thumbs Up
Post #615908 Mon Jul 19 2021 4:06pm
gogsy1956
Well, to be honest, it should take no more than 5 mins to remove the headlight so you have nothing to lose either way. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #615909 Mon Jul 19 2021 4:15pm
Iomegas
Hi gogsy yes true I will have a look the dreaded float issue it only happens now and again then clears itself but have the new tank to go in . Thumbs Up
Post #615919 Mon Jul 19 2021 4:58pm
Phil2k
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Mine needs doing too, im going to order one this week
Post #617208 Sun Sep 12 2021 6:23pm
Iomegas
Hi did mine found it easier taking front grill off and RH headlight unit out was easier getting to bottom pipe Thumbs Up
Post #617210 Sun Sep 12 2021 7:25pm
colino
Australia 2012 Range Rover Sport 3.0 TDV6 SE Orkney Grey
L320 coolant tank replacement by removing passenger headligh
Is there a YouTube video for replacing the coolant tank by removing the passenger headlight to get at the difficult bottom hose? I keep getting YouTubes that use a wire extender tool to release the clamp at the bottom from the top of the tank which looks painful! I’d also like to replace the clips with "Jubilee" screw ones so easy access at the bottom is useful.
I can dive in and see what I get but a video beforehand is always helpful and confidence building.
Thanks in advance.
Post #635327 Fri Aug 25 2023 9:07am
TheWojtek
David did one:  Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635332 Fri Aug 25 2023 6:00pm
colino
Hi Wokek,
Yes David's one comes up on all "Googles" but he uses a long wire extender clip remover to get at the bottom hose from the top whereas I read that taking the passenger headlight out is the easiest way.
Post #635336 Fri Aug 25 2023 11:41pm
TheWojtek
Oh, OK, I see now. Yes, I believe removing the headlight (takes some 30 seconds if some WD40 is necessary) and working from the bottom of the tank would be the best way. Just give it a shot. Regards etc.,
Wojtek
Post #635344 Sat Aug 26 2023 10:34am
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
I'm tackling this job tomorrow, was going to remove the light and grill as it looks like and space gain will be helpful.....
CJS
Post #635349 Sat Aug 26 2023 8:54pm
Cpt Jack Sparrow
Hi All
I can confirm that the 60 seconds needed to remove the Nearside headlight and grill makes the job a lot easier with the additional space gained.
Total time to replace for me was less that 30 mins, including cup of tea Rolling with laughter
The thought of the job is a lot worse than the doing. As with most tasks. Thumbs Up
CJS
Post #635385 Mon Aug 28 2023 7:50pm
TheWojtek
Great to hear it, and how did you tackle the bottom hose? Regards etc.,
Wojtek
Post #635399 Tue Aug 29 2023 8:11am
Cpt Jack Sparrow
The bottom hose was the one I thought was going to be the really difficult part of the job.
First of I clamped of the hose about 15cm from the tank, then released the clamp with a standard set of pliers, from the top.
To remove the pipe it was left Hand from the top and right through the headlight opening and a simple jiggle and it popped off.
then exactly the reverse to install after new tank in place...
Hope that helps
CJS
Post #635413 Tue Aug 29 2023 4:42pm
TheWojtek
Difficulty scale, 1-10? Regards etc.,
Wojtek
Post #635419 Tue Aug 29 2023 7:03pm
Cpt Jack Sparrow
in my view its probably a 3
its more fiddly than difficult, bottom hose being the most.
it really does take longer to think about it than do it..
CJS
Post #635435 Wed Aug 30 2023 8:50am
