Home > Maintenance & Modifications > Sagging rear wheel
Sagging rear wheel
Hi everyone,
Just got home and noticed that the driver's side rear corner is sagging quite badly.
Fired up the GAP tool and it shows it at -55 while the other side is -41.
I tried the Valve test routine, but I'm not sure I was doing it right: I was trying to inflate that corner to see if it would deflate again overnight.
How do I test if it's a valve, as opposed to it being a leaking airbag?
thanks --
Post #614520 Tue Jun 08 2021 3:28pm
anyone? Neutral --
Post #614538 Wed Jun 09 2021 8:00am
found this very useful fuse guide, but the EAS one is not in there?
https://docs.google.com/spreadsheets/d/e/2...bq/pubhtml --
Post #614545 Wed Jun 09 2021 9:53am
So yesterday I used the GAP tool to lift the sagging wheel, and then I did not re-enable the EAS when exiting the routine.
Left it overnight, and the wheel is not sagging, so looks like it is the valve block and no the airstrut then. --
Post #614615 Thu Jun 10 2021 8:22am
Oldandconfused
Have you read the current values for the height sensor? I have access to my lads Autel MK808bt code reader and when the RNS corner was high, I could read the voltage at each sensor. Three were around 5v, and the RNS was zero, so wiring or sensor fault. In the end is was a defective sensor. [/b]
Post #614625 Thu Jun 10 2021 12:56pm
Do you know if I can do this with the Gap tool? --
Post #614629 Thu Jun 10 2021 1:41pm
Oldandconfused
I don't but would be surprised if you can't. I'm sure a veteran IID user will be along shortly.
Post #614638 Thu Jun 10 2021 6:39pm
knwatkins
naks, when the car is running, does it inflate to the correct height? If not, you may wish to run the calibration routine on the IID tool, in case the cal values are out of whack. Kev
Post #614649 Thu Jun 10 2021 9:29pm
well, the issue never occured again.
I tested the valves, and LR Stellenbosch re-did the calibration during the recent service and couldn't find any issues.
I'll put it down to one of those weird random LR things. --
Post #615231 Mon Jun 28 2021 10:02am
